Help... where should this go??
Old Aug 24, 2009 | 10:03 AM
numbers5052006's Avatar
Question Help... where should this go??
My check engine soon light came on for about 70 miles when I was out of town then went off. As soon as it came on I pulled over and saw this wire, looks like a ground, that must have come loose. For the life of me I cant seem to find where it goes.
Can one of you guys look at yr engine and let me know.
The light has gone out but I don't want this just floating around in there.
Thanks in advance!
mike
Old Aug 24, 2009 | 10:05 AM
1lancer's Avatar
what is that...i don't have that on my 06 lancer....thanks
Old Aug 24, 2009 | 10:11 AM
ethan169's Avatar
Hmm. I dont have a lancer so I can look at mine but it should basically be fine if you connect it to anything solid that is chassis grounded.
On the second picture you provided there is a what looks like small threaded hole by that silver high pressure line (i think) in between the cap that has an H on it and a wire connector on the left. Looks like it could have been there. Find the right size bolt from a hardware store and bolt it up.
It looks like that ground wire connects to the bottom of that unit there. Which if i had to guess would be something with the EVAP or emissions or something like that.
Good luck!
-Ethan
02 OZ lancer... (I think that is what you are asking)
As for what the wire is, maybe a ground of some sort?
Old Aug 24, 2009 | 10:15 AM
The wire should be grounding something as the other end is bolted onto the bracket/chassis:
Old Aug 24, 2009 | 10:19 AM
ethan169's Avatar
Your absolutely right! I guess i didn't look hard enough. I was under the impression that it was not connected to the chassis.
Im not sure then it this case as I have no experience with your model or one of my own to compare to.
Good luck!
-Ethan
Old Aug 24, 2009 | 05:25 PM
I think I figured it out... quite a while back I had the timing belt replaced. This should be an engine ground wire, attaches to the timing belt cover. Guess that wasn't why the light came on however....
