my 03 lancer es
Old Sep 18, 2009 | 07:00 AM
protolan07's Avatar
Question lifting the rearend of my lancer a half inch.
im looking to raise the rear end of my car just a little so that when i have people in the back the tires dont rub, i have 17s on my car and i also have alot of weight in the trunk due to having a 150lb sub box. what can i do to bring the rear end up like a half inch.
Old Sep 18, 2009 | 08:56 AM
blaze_125's Avatar
Tell your buddies to loose weight.
Seriously... if you tires rub when your buddies are in the back, they are seriously overweight. I' have a dropped suspension, oversized tires(5% taller) and it doesn't rub when I have passengers in the back.
and put that sub box on a diet. Why do you need a box so heavy?
Old Nov 2, 2009 | 07:08 AM
lancerguy0208's Avatar
+1^ That 150lbs is killin your car's fun factor. But if you find some similar-drop springs with a stiffer spring rate it should keep your ride height about the same but they wont sag when there's extra weight in the back. If you still have stock suspension you might as well do springs all around.
Red Dragon
Nov 28, 2016 12:19 PM
Arsenal4Life
Jan 8, 2014 09:58 AM
Thebigjoke1337
Apr 21, 2010 08:57 AM
jid2
Aug 6, 2009 12:12 PM
