SES - Threw x2 P0181 - Fuel Temp Sensor. Fix?
Old Sep 29, 2009 | 09:34 PM
thedeatons's Avatar
DTC P0181: Fuel Tank Temperature Sensor Circuit Range/Performance.
I have seen this is related to TSB #89.
Anyone know how to permanently fix this code?
Last time I saw this code it was thrown along with a P0421. The dealer replaced my cat under warranty, and reflashed my ECU, but now the P0181 is back....
I would like to fix this once and for all.
James
Old Sep 30, 2009 | 03:26 PM
thedeatons's Avatar
So, the dealer told me the fuel tank temp sensor is located on the bottom of the fuel gauge sending unit. You cannot order it seperately, you must order the entire sending unit. From the dealer it is $122.
I may check Auto Zone...
James
Old Aug 9, 2010 | 05:17 PM
thedeatons's Avatar
Does anyone have a fix for this, or perhaps can show TSB 89 to me?
I have searched the net and it seems that P0181 is affiliated with TSB 89.
My county is now doing Emissions Testing, and the SES light is STILL ON!
Do I really need to replace the Fuel Sending Unit?????
James
Old Jul 2, 2011 | 10:34 PM
hilaloruc's Avatar
did you find out about it?
Old Jul 3, 2011 | 06:25 AM
thedeatons's Avatar
Yep. Replaced the sending unit (ordered a Mitsu part through an online distributor) and replaced it in 15 minutes. 3 nuts and a connector basically. Fixed the problem!
Old Oct 25, 2011 | 09:44 AM
shadovarian's Avatar
Do you have picture or some instructions on where it is located? Also is there a periphery fix for this?
Old Oct 25, 2011 | 09:51 AM
thedeatons's Avatar
I attempted a fix when I had the sending unit on my workbench... Didn't work.
I just ordered a new sending unit online for about $55. That fixed it completely.
Basically do this:
Pull rear seat bottom out of car.
Locate fuel gauge sending unit on driver side of car (under the seat you just removed).
Remove electrical connector from sending unit.
Remove three nuts from top of sending unit.
Pull sending unit straight up and out.
Throw old unit away.
Reinstall new unit in reverse of uninstalling old unit.
Done!
James
Old Oct 26, 2011 | 08:02 AM
That is a lot easier than I had thought. I was under the impression that this unit required the tank to be dropped.
You wouldn't happen to know if this is the same part between regular lancer and evo would you?
Old Oct 26, 2011 | 10:27 AM
thedeatons's Avatar
Not sure... Mitsu can tell you, or a parts breakdown...
James
Old Jun 9, 2018 | 02:15 PM
Drew1's Avatar
P0181
So I see this post is almost 10 years old but hopefully someone can be a little more clear...
I just got P0181 and everything I've read it looks like you replace the main housing that the pump is in (link below).
https://stmtuned.com/products/fuel-pump-holder-oem-evo-7-8-9?variant=819923025929&utm_medium=cpc&utm_source=g oogle&utm_campaign=Google%20Shopping&gclid=CjwKCAj w9e3YBRBcEiwAzjCJuoFtlEyDPGVByAjlUhxnuVoThQ3e6ivGG 4a_aqJ75pm1OVQ0EBEa8hoCz9oQAvD_BwE
can anyone confirm on deny that? Since that is more than 3 screws and an exchange as described above.
another thread shows an inaccessible hole between the two access points as to where the sensor is.
Old Jun 10, 2018 | 07:09 PM
Drew1's Avatar
looks like I found the correct part.
Temp Sensor - Mitsubishi (MN120016)
but no access that I can find. Anyone know anything more about this?
Old Sep 24, 2018 | 07:06 PM
Drew1's Avatar
Ended up replacing with the part above from a parted out car. Code was fixed. They do not stock this part in the US and it is weeks from Japan if ordered by dealer. I ended up using an Oscillating tool to precision cut a hole and then picked up a fuel door to secure the hold back up. No access hole because it is not a sensor utilized on JDM vehicles, it is only used by USDM because of EGR emission stuff.
Old Dec 6, 2018 | 06:55 PM
city's Avatar
Do you have any pictures of where you had to cut to access the fuel temp sensor?
mr2driver
Aug 1, 2011 06:16 AM
WADADLIG_OZ
Lancer Troubleshooting
10
Jun 23, 2009 09:25 AM
thedeatons
19
Jan 29, 2009 11:41 AM
BadazzCR
Aug 23, 2008 07:40 AM
