Valve Cover
Old Feb 10, 2010 | 09:23 AM
napoli's Avatar
Valve Cover
I have a 2003 Lancer OZ with 145k miles on it. I brought my car in for a brake change and the shop mentioned that my valve cover is leaking and that I should have it replaced. Another mechanic a couple years back mentioned that it was "misting oil" and that it wasn't that big a deal. Does the valve cover really need to be replaced or do you think it is just the valve cover gasket?
Old Feb 10, 2010 | 09:43 AM
03lances's Avatar
Wierd there saying you have basically a hole somewhere in your valve cover itself? I say first buy a valve cover gasket and see if that fixes the issue there not too expensive
Old Feb 10, 2010 | 01:17 PM
napoli's Avatar
One of the other mechanics at the shop said that he probably meant the gasket. That makes me feel better.
Old Feb 10, 2010 | 01:43 PM
mcgarvey's Avatar
Yep, just the gasket. The valve cover itself doesn't go bad. Where in NJ are you located? I'm a former Mitsu mechanic (now with toyota) if you need any work done, I can definitely beat what other shops charge. Let me know, I'm located in Gloucester county.
