Radio shuts off
Old Aug 27, 2010 | 09:50 PM
bvasquez12's Avatar
Radio shuts off
Okay ive been having this strange problem where ill be driving, and the radio and clock lose power out of nowhere.my power locks also stop working, all i have to do is open the fuse box and push the little yellow box thing that holds the fuses for these accessories all the way in, it fixes the problem for a while until it happens again eventually. whats causing this to happen.??
Old Aug 28, 2010 | 04:23 AM
mci2727's Avatar
Loose connection?
Have you tried replacing the fuse and yellow box?
Old Aug 28, 2010 | 07:57 PM
bvasquez12's Avatar
didnt think of replacing it because its not blown lol.
Old Aug 28, 2010 | 09:59 PM
mci2727's Avatar
It could be either a loose connection and may need to rewire that fuse to a different (unused) fuse or replace the fuse.
I'd replace the fuse and see if it fixes it.
Cheap fix if it does.
Old Aug 30, 2010 | 09:50 PM
bvasquez12's Avatar
yea ill replace the fuses, probably without the little yellow box, unless its necessary.
Old Aug 31, 2010 | 04:09 AM
mci2727's Avatar
I have read that it's not needed but I've neveer tried that myself so I don't know.
Old Sep 4, 2010 | 06:13 PM
bvasquez12's Avatar
okay so i looked at it, and the little metal prong inside the fuse box seems to be sinking down, is there a way to push it back up. ill probably have to remove the fuse box and take it apart right.
Old Sep 4, 2010 | 08:16 PM
mci2727's Avatar
Yeah, as far as I know you have to get to the back of the box to push it back in and secure it.
Unless you can hook it with a o-ring hook and pull it out?
Old Sep 27, 2010 | 09:39 AM
evil03's Avatar
bump i have the same problem any other fix?
Old Sep 27, 2010 | 12:27 PM
bvasquez12's Avatar
trade the car in for an evo, lol jk. idk its not my problem anymore but what i was planning on doing was removing the fuse box, and maybe uncovering the bottom plastic piece to see if i can maybe push the metal clip back up.
Old Sep 27, 2010 | 04:17 PM
evil03's Avatar
so just check the fuse box connection again? and we are planing to
Old Sep 27, 2010 | 10:24 PM
bvasquez12's Avatar
yea just recheck it.
