Part # req. and brake question
Old Jan 14, 2004 | 12:05 PM
HobieKopek's Avatar
Does anyone happen to know the part # of the hard section of brake line (the metal tubing running from the master cyl) for the front driver's side brake? The copper/brass/whatever hex fitting where it connects to the rubber brake line is a little stripped from my trying to remove the brake lines, and I may end up replacing it in the spring when I do my brakes.
On a related note...those of you who have removed/replaced you brake lines, did you have similar problems or is it just me? I cleaned the head using brake cleaner (very effective at breaking up the gunk and undercarriage coating) and it still would not loosen for me.
Any help would be appreciated.
