Damn radiator...!!!
Old Apr 29, 2012 | 02:04 PM
mtype_06's Avatar
Damn radiator...!!!
So after extensive googling of the 'net and this forum,I still have yet to find a solution!
My 2006 lancer Ed overheats only after idleing for about 30-40 mins, a little bit faster if I turn A/C on. I checked for fuse problems, but Ive never had any fuses in the spots that shows where they should be on the diagram, as far as relays and things of that sort, what process do I go through to see what's broken, or should I just replace em all
Old Apr 29, 2012 | 02:20 PM
meckert's Avatar
Fuses and relays don't go hand in hand with over heating. Is your fan working? If so, check your coolent cap and oild filler cap for greyish foam---if so, Sounds like you have a blown headgasket if you overheating at idle.
Old Apr 29, 2012 | 02:53 PM
Green_Bandit's Avatar
More than likely the culprit is the fan relay. They're notorious for going out. Also your radiator cap could be shot.
Turn on your ac and see if your fans turn on. MAKE SURE IT DOESN'T OVERHEAT! If it starts getting high turn on your heat to the max. You don't want to deal with a warped head.
Old Apr 29, 2012 | 03:08 PM
jakermeister's Avatar
Keep it simple first and go with what Green_Bandit said
Old May 1, 2012 | 10:05 AM
mtype_06's Avatar
Well see that is the problem I think, the fans don't turn on at all over any timespan after turning on A/C, also I'm not worried about blowing anything...the overheating doesn't start with A/C on for about 30-40mins, I figured it was the relay because I've never had fuses in the spaces in either fuse box
Old May 2, 2012 | 10:16 AM
If your fans don't turn on with the ac then it's the fan relay box next to the fans. Dealer or try your luck with a used one at a junkyard.
Old Jun 5, 2012 | 05:17 PM
Seifer780's Avatar
Did you ever fix your problem with your cooling fans not coming on properly?
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
sxperia101
Sep 1, 2015 02:33 AM
czapski
Nov 26, 2008 07:01 PM
aspensvt16
Feb 25, 2008 02:50 AM
nebolic
Dec 23, 2003 08:42 PM
