O2 Sensor for 2002 lancer
Old Mar 22, 2013 | 07:35 PM
Sairo's Avatar
Can you recommend a good aftermarket oxygen sensor for 02 lancer?
Old Mar 23, 2013 | 03:49 PM
Green_Bandit's Avatar
Bosch
Old Apr 17, 2013 | 10:02 PM
SUDDOTH 2's Avatar
i got the denzo and i think it was fine
Old Apr 18, 2013 | 06:21 AM
02modlanceroz's Avatar
I agree with green bandit, go with bosch. A few yrs back I would of said a different company for the downstream one. back then it was $300. But they are around $90 for downstream now and $60 for the upstream. Make sure to get exact fit and not universal
Old May 2, 2013 | 08:52 PM
DVanDuzer's Avatar
This will get rid of the P0421 code that is flipping?
Trying to pass smog and the code keeps turning on, I switched the front o2 but it still getting a check engine light. Getting the second o2 tomorrow and replacing that.
Hopefully that fixes it. Any other ideas if that doesnt work? Everything is stock.
Old May 2, 2013 | 10:34 PM
There is a recall for the warm up catalyst. call your dealer and see about getting it reprogrammed
Old May 5, 2013 | 10:53 AM
luis argu's Avatar
it is a wrong code the ECU, I am with the same problem, but with a new ROM will be solved,
by the way if anyone has a ROM for lancer OZ 2003 and it doesn't have the code error it will be great for me!
Old May 6, 2013 | 01:23 AM
DVanDuzer's Avatar
I called the dealership and they said there were no open recalls for my car.
I was running a testpipe for 2 years so Im going to bet the rear o2 is shot.
Replacing that today. Hopefully it fixes it.
Old May 6, 2013 | 06:03 AM
luis argu's Avatar
ok luck Man
Old May 7, 2013 | 05:16 AM
Sairo's Avatar
Denso O2 Sensor
I just got a Denso O2 Sensor (upstream) at Advance Auto Parts through online purchase. I got the direct fit for $64.99, less $20 for the online code discount plus $10 mail-in rebate. The total cost $38.92 after mail in rebate.
Old May 7, 2013 | 07:08 AM
eusgen's Avatar
^ this
Old May 14, 2013 | 04:48 PM
DVanDuzer's Avatar
I got the o2... put it in and its still throwing the code...
Old May 14, 2013 | 05:06 PM
eusgen's Avatar
Which o2 sensor? there are two.
Old May 15, 2013 | 04:10 AM
DVanDuzer's Avatar
I replaced both. Front and Rear
Old May 15, 2013 | 06:23 AM
Sairo's Avatar
How do you flash the ROM to the ECU? What equipment do you use?
