2002 gauge cluster lights
Old Dec 4, 2016 | 11:13 PM
DRKalinowski's Avatar
I've been reading all the threads I can about the bulbs for the speedo, tac, temp and fuel. It seems the general consensus is that if you are going to use LED a 74 with 360 degree out put is the best option. on that note, i found these https://www.superbrightleds.com/more...rofit-car/228/
My question is, what is the correct size/type twist lock socket to buy and it looks like I need to solder wire leads to that particular LED.. (I would reuse the sockets from current cluster but two of them broke.. ) I tried the whole painting the factory bulbs and it worked some what, but the paint I got is flaking off and I dont feel like messing with it any more.
Thanks for any info/input this forum saved me a lot of money with its info on messed up shifting in the auto trans. (new sensors so much cheaper than new trans lol)
Old Dec 28, 2016 | 09:46 AM
02modlanceroz's Avatar
NEO5-BHP: 5mm NEO5-xH are a direct swap
https://www.superbrightleds.com/more...panel-led/221/
nekkidlad
10
Sep 11, 2015 05:16 AM
05RalliartJake
Mar 22, 2013 07:23 PM
NoTiGuY
May 12, 2005 05:05 PM
