Cooling Fan Help Asap!
Old Feb 3, 2018 | 04:03 PM
CokeZero's Avatar
Hello everyone my son has a 2008 Lancer GTS. The cooling fans haven’t been coming on. I tested direct power, they work. I replaced all the relays and fuses even though none appeard to be faulty. Still nothing.
Then I find the motor on the passenger side electrical connector is a little bad. I got it to work by pulling it towards one side.
The confusing part is that when I turn the ac on they don’t turn on like they should. (Maybe that’s because his compressor doesn’t kick on due to having no ac?)
And lastly if I pull this relay out and leave the other ones in, the fans turn on and run.
Basically checked everything and all is well beside that one connection. Point me in the right direction?
Attached Thumbnails Cooling Fan Help Asap!-4b0bc245-e3f9-4e74-aa88-29e76ef36a2a.jpeg
Old Feb 13, 2018 | 08:40 PM
Wanchai Panpron's Avatar
Do you have circuit diagram ?
I will find out.
MisUnderStood
19
Nov 25, 2016 03:33 PM
400whp350wtq
Aug 2, 2013 08:09 AM
SavEVOIX
Feb 23, 2011 07:21 PM
Gruppe-S
51
Oct 15, 2009 12:36 PM
eling99
Jun 15, 2005 07:23 AM
