Speedometer stopped working.
Old Oct 23, 2019 | 05:56 PM
teindu's Avatar
Speedometer stopped working. [Fixed]
I originaly had issues with my speedometer not showing anything. After replacing the speed sensor due to an engine code, it continued to not work. I replaced the ECM, ECU, connector to the speed sensor, none of them fixed the issue. I replaced the cluster and still had no fix. I checked each wire and connector. Later I found the OZ cluster i purchased did not work. My stock ES cluster did not also work.
After some time thinking and replacing everything. I decided to finally try replacing the fuse block located under the dash. Suddenly the speedometer came back to life. I'm still confused if it was the pins or something else internally or maybe I just moved a connector just right. It's the weirdest issue I've ever had. Ill update more if I find the true reason for this.
Old Aug 12, 2022 | 05:36 AM
BabyFace340's Avatar
I have done all that to the car but i haven't checked the fuse box good but i did check the fuse on it so ill go ahead and check the fuse box once more and see if that helps thank for this post.
shomesomesho
May 27, 2016 07:27 PM
211Ratsbud
Dec 11, 2013 05:17 PM
ExViTermini
Mar 20, 2008 01:32 PM
