Burnt Fuse
Old Apr 21, 2004 | 03:05 PM
Ironwolf's Avatar
Burnt Fuse
2002 Lancer OZ . Fusible link on the positive battery terminal blew.
Where should I start ?
Old Apr 21, 2004 | 03:09 PM
Nitrous2K3's Avatar
what do you mean, where should you start? Is the power cable running to an amp, fog lights, etc... give a little more info so we can help.
Old Apr 21, 2004 | 03:20 PM
Ironwolf's Avatar
Fusible link
Look at your positive terminal on the battery. Wire coming from the side to the terminal (fusible link in between.
I believe thats where the alternator sends its current for recharge. I will check alternator output first.
Old Apr 21, 2004 | 05:35 PM
sdhotwn's Avatar
I believe he is asking what you mean by "where should I start". in other words are you asking what could have blown the fuse or what?
Old Sep 19, 2006 | 07:47 PM
Evo_Jay's Avatar
Ironwolf, did you every fix the terminal?? DId you just get one from the dealership??
Old Sep 20, 2006 | 06:18 AM
Ironwolf's Avatar
Fusible Link
Yea, that solved the problem. The fuse coming off the positive terminal. (OZ)
I was afraid it would blow again. Total success.
I sold the car to my nephew. I bought a damaged Evo from california.
Car complete except for lights problems. High beam,fogs and parking lights do not
work. I changed the front ECU. No luck. I am trying to avoid going to the dealer.
Might have no choice. Body control module Etacs may need replacement programming. Do not have enough info on this. Stuck
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
