Flip-Flop trunk help.
Old Aug 13, 2004 | 07:41 PM
howdydee's Avatar
Ive have boughten all the stuff to mod my "es" trunk into a flip-flop one. But i do not know how to LOL. Has any1 had any experience in this? Or could help me through it? I would greatly appreciate it! Lol, sorry if i sound like a newb or something but ya..... Thanks to any1 that could help!
Heres a pic of what i want.
Old Aug 13, 2004 | 08:30 PM
Myszkewicz's Avatar
Where did you buy the kit to do that, that it didn't come with installation instructions?
Old Aug 13, 2004 | 08:32 PM
howdydee's Avatar
i didnt buy a kit.... the friend i know... (his lancer in the picture) told me what i need... but he went on vacation and i cant ask him how to set it up lol.
Old Aug 13, 2004 | 08:36 PM
Myszkewicz's Avatar
It looks like you just replace the stock hinges with some different ones, so the whole trunklid pops up and swings forward a bit, rather than just levering up and forward.
Old Aug 13, 2004 | 09:01 PM
howdydee's Avatar
sounds right...... but has any1 done this before to have specific ideas?
Old Aug 14, 2004 | 02:55 AM
hectik's Avatar
hmmm...shoot i wouldn't mind doin this to my lancer either....can ya post what u need and how???
Old Aug 15, 2004 | 08:51 AM
itscypha's Avatar
lol
Old Aug 15, 2004 | 08:55 AM
itscypha's Avatar
my bad evom was actin a lil out...but ya its easy remove the 4 ten mm bolts then those hinges u got u drill hole for them on the beam the go up n down to pull ur trunk up but have the hinge lay flush like the lil thing that looks liek dis in da middle ()---() should lay at the end of the beam. drillholes screw in. then after u did it to both sides putt he trunk back on wit sum1 helpin u n bolt the bottom ones on the stock line( youll see the lines) the drill holes on ur trunk n bolt them in. then if ur doin latches drill hole for them n put em in n u got it done. after u remove the bottom screws....basic install need more info n better instructions ill tell ya jus pm me or post
Old Aug 15, 2004 | 09:15 AM
hectik's Avatar
what kinda hinges do you recommend?
Old Aug 15, 2004 | 09:16 AM
hectik's Avatar
well yea...a nice detailed post would be great...with some pics.... =) thanx!
Old Aug 15, 2004 | 12:54 PM
army685's Avatar
all u need 2 do is go 2 home depot and buy some small hinges and u just take out tha outside bolts from your trunk and put your new hindges and there u go! i couldent wit mine cause my spoiler is 2 heavy i have tha evo 7 spoiler
Old Oct 25, 2004 | 07:11 PM
Mor-Speed's Avatar
custom trunk flip kit
I make a custom trunk flip kit that can stop in multible positions and handles heavy wings no problem.
It uses hitch pins and custom steel braket so you can pick your setings.
Old Oct 27, 2004 | 01:04 PM
Kelspar's Avatar
Your first post?
Old Oct 27, 2004 | 01:14 PM
twardnw's Avatar
apparently so
Old Oct 27, 2004 | 01:54 PM
.L.'s Avatar
.L.
my buddy did this to his altima. i remember he got the hinges from home depot. just becareful when you drill the holes, and make sure everything lines up right. he drilled the holes a little sloppy, and now the trunk dosent close fully. one side sticks up a little higher than the other.
