Bad tires causing vibrations?
When traveling above 65-75 my steering wheel will vibrate from side to side with about an inch of movement. I took it in and after looking at it the dealer blamed it on the tires. My right front tire is a worn a lot from burnouts(stupid kids...what can you do...lol) but I know it did it before that tire was worn out unevenly like that. Could it really be the tire and me not noticing the vibration before or could it be something else? They said the ball joints werent worn at all. And another ? on the side. Is it normal for only the right tire to spin when you burnout/get stuck in the snow?
maybe your tires are just out of balance?
Originally Posted by 03_Lancer_ES
(Post 3999901)
Spend 20 dollars get the front wheels balanced. If the problem is still there time for new tires.
but i would rather spend my money for the dealer to tell me i need new tires!! lol. between jobs right now so im broke. start new job tomorrow so my first few paychecks are going to fixing all my problems.
same happen to me but my tires had flat spots in them, then about a week or two later i had a 2inch gash on the bottom of my tire
usual cause is the tires arnt balanced.. Either not balanced or have mud/snow in them which causes them to be unbalanced. The weights could have fallen off which would cause this.
Then a problem could be uneven worn tire which would cause it to be unbalanced...... this would be caused by a bad allignment. |
+1 for checking the balance. 99% of the time that's the problem.
ill do that as soon as i have a chance to, the ballancing, but i think my tires have some flat spots from a deer i about nailed. thanks for all the feedback
