Wierd "ticking" noise
I have an odd issue going on with my 2006 es. When it is first started and I put her into reverse and begin backing out, there is a very loud ticking noise. When I throw it into drive and it cycles through all the gears once, it seems to get quieter, however it's still occurring.
I popped the hood and it sounds like it's coming from the alternator or something else that the same belt is running. I've looked at some previous Mitsu cars in the past and noticed there is a slight ticking with many of the 4 cylinder vehicles, but this particular noise seems louder and more abnormal. I'm worried because I have installed an after market head unit and have ran amp power cable through the firewall. Last time I took my car into Mitsu for a completely unrelated issue they told me by doing that I "more than likely have voided the warranty" which is complete bull****. Does anyone have an idea of what it could be or has anyone had the same or similar problem? |
i have this on my injectors.
When you say "first started", it is still cold when you put it into gear? Does it do it when the car is cold/warm or all the time?
Also, Auto or Man? Aftermarket parts do not void your warranty unless they can be proven to have caused the problem. You have to love that law. |
In IL, I bet it's cold right now. It's probablt the usual DSM tick-tock from the lifters... maybe try heavier oil weight for the winter?
does the ticking get faster when you rev the engine? or is it consistent either at all rpms?
The heavy ticking only happens on a cold start, however, yes the constant ticking does get faster as the rpms increase.
Oh, it's automatic by the way. |
could be something simple..check your oil level..make sure your oil is full
^^Yes check your oil level.
Here is something to try to see if is coming from the top end. Use a long screwdriver to see if you can locate the tick (by putting it to your ear and the engine). If you can locate the loudest point where you hear it, we can give you a little better idea of what to look for. Since it changes with RPM it could be a number of things internal of external to the engine. |
Dude, they all tick. It's completely normal and happens most at idle. Nothing's wrong and it's not hurting anything. They're just noisy motors.
Please DON'T put heavier oil in for the winter. Valvetrain noise is caused by low oil flow to the top end. Therefore, when it's cold and oil is more viscous, put LIGHTER oil if anything. 0w30 in cold climates is ideal. |
Originally Posted by mcgarvey
(Post 5060217)
Please DON'T put heavier oil in for the winter. Valvetrain noise is caused by low oil flow to the top end. Therefore, when it's cold and oil is more viscous, put LIGHTER oil if anything. 0w30 in cold climates is ideal. check that and let us know |
Plenty of oil in the engine. The noise the engine makes is a separate issue I've found. It seems like this periodical, louder noise is coming from the alternator or something else on the same belt. There is no belt wear. Maybe it's a bearing in the alternator or something. I guess I'll just listen for it and see if it gets worse before deciding to take it to Mitsu.
just take it and have it looked at..shouldn't cost you anything..
or if they do take it to some other shop that give free estimates and have them look at it free estimates are a wonderful thing |
