P0171 - System To Lean
so ive been having idle issues as of late when i installed the intake manifold and the throttle body .
today i get cel , and system is to lean. urgh. any suggestions.. im starting to get a little frustrated. |
Check for vacuum leaks. Also make sure the MAP sensor is reading manifold vacuum. Also try cleaning your MAF sensor. The idle issue definitely sounds like a vacuum leak. Is the idle too high?
