P0171 - System To Lean
Old Jan 7, 2009 | 07:50 PM
RaiNFaLL's Avatar
so ive been having idle issues as of late when i installed the intake manifold and the throttle body .
today i get cel , and system is to lean.
urgh. any suggestions.. im starting to get a little frustrated.
Old Jan 10, 2009 | 02:19 PM
mcgarvey's Avatar
Check for vacuum leaks. Also make sure the MAP sensor is reading manifold vacuum. Also try cleaning your MAF sensor. The idle issue definitely sounds like a vacuum leak. Is the idle too high?
