-   Lancer Troubleshooting (https://www.evolutionm.net/forums/lancer-troubleshooting-203/)
-   -   What's wrong with the engine?? (https://www.evolutionm.net/forums/lancer-troubleshooting/395703-whats-wrong-engine.html)
stana Jan 26, 2009 01:59 PM
It takes a really long time, much more than normal ,for my rpm to come down from 3 or 4k to normal idle rpm. It does not happen all the time. Im taking my gts to the dealer on Wednesday, but I just wanted to see if any one of you know what the problem is or if anyone had this problem.
lancerrallygirl Jan 26, 2009 02:05 PM
mine did the same last yr but it was after running for a lil while with no movement and mine only went to 1500...... i never could figure it out and it just kinda seemed to go away
MasterAK Jan 27, 2009 05:24 AM
It happens to me too. There is no fix as far as I know.
https://www.evolutionm.net/forums/la...-too-long.html
https://www.evolutionm.net/forums/la...d-revving.html
stana Jan 27, 2009 08:04 PM
thanks, now i know what i need to do
anbuzero Jan 28, 2009 03:10 PM
ive had this happen to me several times in my cvt es. it feels like its in L gear but the screen shows D. it only happens when i floor it and the wheels slip a bit. i usually put it into N and back into D and its back to normal
CamShaft Jan 28, 2009 03:58 PM
How long have you owned your vehicle? If it is under 15000kms then the engine is still in the learning process and the high revs once you come to a stop are supposed to clean out the cat of any extra hydrocarbons that may have accumulated due to high speed driving (highway) or moderate to heavy acceleration. This is so mitsubishi can conform the the tight regulations for emissions. This is normal. You will either notice it to decrease after 15000kms or just accept it into the cars function. For me I don't know whether it has decreased or I just got used to it.
stana Jan 29, 2009 01:24 PM
I bought it 2 months ago, used at 50000 km,I haven't had any problems like what some people mentioned on the other thread,but I revved it once and it seemed odd tome that it does this since i have never seen this happen before on any other car.
