weird revving??
Old Apr 13, 2008 | 08:55 AM
AhFuJai's Avatar
Question weird revving??
is it normal for the rev to jump when i shift up? i mean when i shift from 1st to 2nd around 2500rpm, i press in the clutch then shift to 2nd gear but instead of the rpm dropping as soon as the clutch is engaged, it jumps to 3000rpm then drop... i know its not because of my gas pedal because i let it go completely and other cars ive driven isnt like this... just wanted to see if its my car or something... btw my car is still new around 400km only
Old Apr 13, 2008 | 08:57 AM
Curt@MrLed's Avatar
Former Vendor
Bad iac controller maybe. Go to the dealer.
Old Apr 13, 2008 | 09:23 AM
kalpakiotis's Avatar
its probably normal cuz ur car is still new. btw, theres a whole other thread on this.
Old Apr 13, 2008 | 09:24 AM
M@verik's Avatar
It could very well be ur gas pedal. Ur not supposed to keep it pressed at all as u change gears.
master.axu's Avatar
Or it may be an emissions related software setting, that prevents unburnt fuel to be released in the atmosphere...my 2 cents
Old Apr 13, 2008 | 09:30 AM
AhFuJai's Avatar
anyone with a 5spd 08 tell me if this happens to them? and it only seems to happen on lower gear like 1-2-3 after its normal
Old Apr 13, 2008 | 09:32 AM
AhFuJai's Avatar
btw its not the same as high revving coming out of highway or something like that.. my car doesnt do that its just the rpm jumps everytime i switch gear
Old Apr 13, 2008 | 09:37 AM
the_cosworth's Avatar
when you push in your clutch an algorithm runs in your ECU so that your RPMS stay high or jump a bit. It is normal as long as it jumps either a couple hundred or stays the same rpm for a second.
IIRC (dont really remember) but I think it is when you drive it a bit harder if you close the throttle right away you can burn out your catalytic converter so it manages the transition a bit smoother to increase the life of the cat and better on emissions. The other thing the Mitsu engineers might have done was to put in an idle increase algorithm so that your Rpms dont drop when your transitioning between gears
Old Apr 13, 2008 | 10:00 AM
AhFuJai's Avatar
^^ thanks but does ur car do that also??
Old Apr 13, 2008 | 11:52 AM
Blacksheepdj's Avatar
As said, one thread on this is enough. Please post in the other one if the future.
acct918
10
Mar 9, 2019 04:38 AM
Lancer Driver
Lancer Engine Management / Tuning Forums
Feb 26, 2017 04:08 PM
johnnycage
20
May 11, 2012 01:20 PM
aycynokia
May 10, 2011 05:33 AM
Alex Rodriguez
47
Feb 25, 2009 08:39 PM
