engine wont turn over
It cranks but doesnt start. I have power to the coils but no spark. All fuses are good. What could be the problem?
what type of work have you done to the motor recently? i did the timing belt on my car and i busted the crank sensor.
I changed the battery to an Optima Yellow Top a couple days ago and had no problems. I drove it twice today with no problems. I disconnected only the + terminal after that to put a height adapter in so my tie down would work, and its been a problem ever since.
Originally Posted by Boostedlancer$
(Post 7792713)
Im having kinda the same problem. i dont have a code reader. i really need one, i know!. i'm not getting any spark what so ever so i replaced the crank sensor and its still not the problem. i've been told it could be the cam shaft sensor but if so wouldn't the car still run? what could be wrong with my car? im confused
Originally Posted by Jglenn0688
(Post 7795996)
Actually, heres my story for the camshaft sensor. I bought a mirage head from a junkyard and put it on my motor and the sensing piece of metal the sensor detects was missing from the end of the camshaft, therefore acting as though my sensor was bad since it wasnt sensing anything. The end result was that I had absolutely no spark to my coils. So, If your getting spark, the camshaft sensor isnt the culprit. The next step is to check for fuel. I know you might not have done many things before it quit, but the steps are usually spark, fuel, then compression test. Ive found all my problems usually within the first two. So check the spark from all four plugs, then verify that you are getting fuel. And if all that comes back as good, then compression test and leakdown.
i actuallty talked to a mitsubishi dealership mechanic on the phone today and he told me that the camshaft sensor intermingles with the crankshaft sensor. he said that if the camshaft sensor was bad then it wouldn't be sending the position of the cams to tell which plug to fire. I.E. no spark. im not sure if this is absolutely the problem yet but i have ordered the part and now i'll just have to wait. thanks for the quick replies though.
It was just a stupid fuse missing. Oh well, at least it didnt cost me anything to fix.
Originally Posted by 03lances
(Post 7796309)
Normally yes your car would still run if this was the case, poorly but should still run. Check for power to your coils first. Have you checked to confirm no spark on all plugs? No spark could be bad plugs, bad coils, bad wires, no power. I know this may sound dumb but have you checked all your fuses regardless of what it says its for? I would do this too, it might be a relay maybe?
which fuse was it if u dont mind me asking? i just wanna know just in case my car dont crank after i replace the cam sensor
My guess would be the ignition fuse as that would cause no spark. Why are you gonna replace the cam sensor still if there is nothing wrong with it?
The mitsubishi mechanic told me that if i replaced the crank sensor and it didn't work then the cam sensor is most likely the problem. i'll find out tomorrow when i put it in
Good ol mitsu mechanics. You know, ive read more negative reviews on mitsubishi certified mechanics and how they sell you stuff you dont need than i have on any other type of certified mechanic. And i am talking about the stealership mechanics. In my experience, they have horrible customer service, and after the third time they tried to sell me something i didnt need, i stopped going to them for help. their answer usually is "well this MIGHT fix it. all we can do is try." Anyways, sorry for the rant, but i hope the piece fixes your problem.
I had a problem like this last year in the cold. Turns out I blew out the fuse to my fuel pump. I believe it's a 15amp and I just swapped it out with the windshield wiper fuse so I could get my car started to go buy some fuses at the local auto store.
