how can i install Windshield Washer Nozzle lights.
I bought a pair of lights, but I have no idea how to install this thing. If any of you have installed it, can you tell me how to do it?
all you need is the strongest super glue you can find. just glue it on where ever you desire the lights to be.
didnt it come with instructions?
Link |
yeah well but it was so simple. basically it told me to remove the existing ones and replace the nozzle, and connect the wires. i need more detailed information than that. for examplt, how to remove heat shield under the roof, etc.
I had them on my car, but then i took them off. Its easy to install you dont need to remove the head shield.
First on the hood where the windsheild jets are you take them off. Follow the jet spray lines to the holes on the bottom of the good you pull those off and then you have to clamp the inside of the nozzel using a needle nose pliersand then you pull them out. then you put your news ones on. Mine came with screws do i didnt need to glue mine on. After you get them on you put eh jet spray lines on and then take your wires that you got and tap them intoyour head lights. I used wire tappers for this. After that you turn on your head lights and see if they work. |
if i just pull the nozzles out, would they come out? should i use a plier for it? And is it easy to insert to hose in to the lights? because, when i looked at it, i didn't have enough space to put my fingers through. i don't know... why did you take them out?
i have mine installed, i really only installed them cuz there chrome, adds a little extra flare, i cant really have them on, ive been pulled over 3 times for it, hehe luckly i know the cops around here, anyways, you shouldnt have to remove anything to put them in, other than the stock washers, they pop up thru the hood, and then hook the wores to one of your side markers so that way when you turn on your parking lights the washers come on
Link |
if i just pull the nozzles out, would they come out? should i use a plier for it? And is it easy to insert to hose in to the lights? because, when i looked at it, i didn't have enough space to put my fingers through. i don't know... why did you take them out? |
