Nissan Maxima: Dump Valves vs. BOV Valves
Old Nov 13, 2002 | 03:29 PM
Guack007's Avatar
Heres a ? that may or may not quite apply. I have a 2k Maxima with a short ram intake on it(no turbo,completelystock except for the intake). Every now and then it will stall when I put the clutch in to come to a stop, especially if I put it in at a higher RPM and let the engines RPM's "fall" back down to idle. Has any one ever had this promplem? is there a fix for it?
Thnx
Old Nov 13, 2002 | 04:36 PM
zlancer's Avatar
i'm not too familiar with the Maxima's engine but if it is MAS then did you remove it completely?? also check for any vaccuum leaks...try asking this question on a maxima forum...i'm sure they can help you more.
Old Nov 14, 2002 | 01:01 AM
Guack007's Avatar
thnx anyways
Old Nov 14, 2002 | 05:50 AM
ru4real's Avatar
Thnx
Did it do this with the stock intake?
Have you had the "Fuel Cut" TSB NTB01-018 for 5th gen Manual Trannies performed on your car, or any other TSB's related to the engine or transmission?
TSBs for 5th gen Maxima
