WRX questions
Old May 12, 2005 | 01:28 AM
Rcebowl's Avatar
your answer too EVERY wrx issue can be found within this site....
http://www.mattrandolph.com/wrx.htm
Old May 12, 2005 | 02:08 PM
pgmike's Avatar
Originally Posted by erockOZ
OH, and what is a cutout? havn't run into that on clubwrx yet. Thanks again
a y-pipe welded after your dp that has a plate to toggle making the exhaust gasses to go thru the stock exhaust pipes or straight out from the other side of the Y to the open air.
Old May 13, 2005 | 08:32 PM
erockOZ's Avatar
From: Northwest Chicago Subs - Serving in Korea till 09
thanks mike, as normal you continue to spread your wisdom to me.
Old Jul 7, 2005 | 12:12 AM
CRVdrftR05's Avatar
I was wondering. And since the title says WRX Qs what's the engine code of a WRX? Is it EJ25 with a smaller turbo?
Old Jul 7, 2005 | 10:51 PM
CRVdrftR05's Avatar
bump my question. sorry if i took over the thread.
Old Jul 8, 2005 | 10:11 AM
erockOZ's Avatar
Alright, did a bit of research for you and from what i've read, I believe the EJ25 is used to discripe the 2.5L engine that Subaru makes. if this is true, the the WRX uses a EJ20 becuase it is a 2.0 engine. I've been looking for the USDM WRX engine code and belive it is EJ205. I have been told that the STi is a EJ257. Anyone that can help, feel free to chime in.
As the the second part of the quesion, the turbo is a bit larger and is helped with a larger TMIC, higher flowing injectors "pinks", and a slightly more powerful fuel pump.
Lastly, you did not hyjack my thread, it was dead for a while now. But all WRX questions are welcome here. Helps me learn too.
Old Jul 8, 2005 | 10:14 AM
erockOZ's Avatar
alright, a little more info. I know the STi used to be 2.0 and have found a link that might help you out a bit more. I'm not taking the time to make it a link cause I feel lazy right now so you have to copy and paste.
http://forums.nasioc.com/forums/show...dm+engine+code
^ change in mind
Old Jul 8, 2005 | 11:10 AM
STLlucas's Avatar
nasioc is definatly one of the better websites......also, the guys at fastwrx.com are always good if you buy parts from them (as far as advice and what not). They have a pretty decent tuning guide on their website.
Old Jul 8, 2005 | 12:02 PM
CRVdrftR05's Avatar
cool cool. Thanks guys. I'll relay the info to my friend. He's getting a WRX soon and we were just wondering if the engines were close to JDM so we could build something *close* to the STi overseas.
Old Jul 8, 2005 | 10:05 PM
erockOZ's Avatar
if you want to make something close to a JDM STi, why not do an STi engine swap. Find a high mile wrx for a good price and drop in a JDM in it. Just a thought. groups has some engines in stock always if you are interested.
I like nasioc and clubWRX. Club dosen't get a ton of people or vendors but is a nice little place to do some research on.
Old Jul 9, 2005 | 01:14 AM
Evo_Jay's Avatar
the stock boost max is 13.5 psi, i just got rid of my rex for my evo, also check out the forum ran by cobb, i had cobb stage 1 (which is the AccessPort) and i really liked it. it had more power & felt much much smoother and it should of came from subaru like that.
