changing brake pads
Old Dec 16, 2005 | 10:08 PM
evolucion's Avatar
changing brake pads
Was doing some brake pad changing earlier on my dad nissan quest. I tested out the car and the brakes are not as responsive as the new pads should be. Appearantly I bleeded out the brakes. I filled up the brake resivour as needed to the max. I also pumped the brake a million time, but there just not much grips on it. The brake fill much worse than the older brake pads. Did I do something wrong.
Old Dec 17, 2005 | 10:06 AM
BlingBling3314's Avatar
You need to brake in the pads. Find an empty lot or something similar and make many 20-0, 30-0, 60-0, etc stops this should help your pads.
Old Dec 17, 2005 | 10:07 AM
Oh, as far as pedal feel, that's the same right?
Old Dec 17, 2005 | 04:25 PM
evolucion's Avatar
I finally got it to work now. Had to bleed out the air, now it stop like a champ. Dad should be proud After all this time he's been *****ing about me messing around with my car, this should keep his mouth shut for a while
Old Dec 17, 2005 | 04:27 PM
4e0v8o's Avatar
