Problem with 1993 accord... No spark??
Old Dec 21, 2005 | 06:29 PM
expl0d's Avatar
Not getting any spark from the plugs. Timing belt is fine. Any solution? The car just slowly died while driving and wouldnt crank back up. its a f22 motor.
Thanks guys hopefully ill get some suggestions and can avoid getting it towed to a shop.
Old Dec 21, 2005 | 06:33 PM
elhalisf's Avatar
distributor cap for sure.
Old Dec 21, 2005 | 06:59 PM
HobieKopek's Avatar
Timing belt has nothing to do with spark. Definitely check the distributor.
Old Dec 21, 2005 | 08:48 PM
expl0d's Avatar
thanks guys getting a couple parts for it tommarow ill let you know how it works out
Old Dec 22, 2005 | 09:18 AM
evolved04's Avatar
i had this same problem on a 93 accord because i pressure washed the engine bay, and the distributor cap had a hairline crack in it, water got in there, and the car just died. i screwed with it for a few hours before i figured it out. really big pain for a part that didnt cost me more than $10.
Old Dec 22, 2005 | 09:25 AM
evosfly04's Avatar
It could have a problem with the distributor itself hondas are known for that problem...
Old Dec 22, 2005 | 11:47 PM
WHTEVO's Avatar
if you change out your cap and rotor and it is still doing it, which i think it will be. replace the ignitor. these go out on these cars and i have had to replace them many times. good luck.
