Lancer GLX
Lancer GLX
I just got back from a cruise in the Bahamas. Our last stop was in Nassau. In Nassau I was ridding the tour bus and saw a bunch of Lancers including an Evo IV and two Lancer GLX's. What is this GLX badge. In searching, I found three pages of registered rides . I could not find any posts on it. The only thing that comes up is the Passat GLX.
I was able to find this brief write-up on it, but I want more info. Especially on certain stuff like the CVT.
I know I'll probably find enough info on my own here shortly, but half the reason for posting was to also bring this up for discussion. Cause from what I've seen so far, this looks damn cool!
Here's the link you mentioned elsewhere but it's GLS and MX stuff. GLX Limited is yet another one.
here's some GLX stuff
stuff
Any one know this VVV int standard measurements?
Specification of All New Lancer GLXi 1.8 MT
Dimension & Weight
Overall Length (mm) 4480
Overall Width (mm) 1695
Overall Height (mm) 1445
Wheelbase (mm) 2600
Tread Front (mm) 1470
Tread Rear (mm) 1470
Ground Clearance (mm) 165
Curb Weight (kg) 1145
Gross Weight (kg) -
Engine
Engine Type 4G93
Displacement (cc) 1834
Bore x Stroke (mm x mm) 81.0 x 89.0
Compression Ratio -
Max. Power (ps/rpm) 124 / 6.000
Max. Torque (kgm/rpm) 16,4 / 4.500
Fuel System ECI MULTI
Fuel Tank (litre) 50
Fuel Consumption (litre/km) -
Transmission
Transmission Manual Transmission 5 Speeds
Gear Ratio 1st 3.583
Gear Ratio 2nd 1.947
Gear Ratio 3rd 1.379
Gear Ratio 4th 1.030
Gear Ratio 5th 0.767
Gear Ratio Reverse 3.363
Gear Ratio Final 3.722
Steering
Steering Type -
Turn Radius (m) 5
Brake
Brake System Hydraulic with booster
Brake Front Ventilated Disc
Brake Rear Disc
Suspension
Suspension Front Mc. Pherson Strut with coil spring and Stabilizer
Suspension Rear Multilink with coil spring and Stabilizer
Tyre & Wheel
Tyre Size 195/60 R 15
Wheel Alloy x 5
Note: Untuk peningkatan mutu dan penyesuaian terhadap perkembangan teknologi, spesifikasi sewaktu-waktu dapat berubah tanpa pemberitahuan terlebih dahulu.
stuff
Dimension & Weight
Wheelbase (mm) 2600
Gross Weight (kg) -
Engine
Engine Type 4G93
Compression Ratio -
Transmission
Steering
Steering Type -
Turn Radius (m) 5
Brake
Brake Rear Disc
Suspension
Tyre & Wheel
Wheel Alloy x 5
sweet i found the link to the GT w/4G63 N/A
http://www.mitsubishi-motors.com.ph/...t%20lancer.htm
