97 Eclipse Repair Help
What type of radiator support are you talking about? the radiator has two partial "L"shape rounded brackets on top of it which are mounted with 2 10 mm screws on each bracket. Each bracket is located at each side of the top of the radiator, thyen on the bottom of the radiator it has two plastic pins which mount on two wholes with rubber bushings.
They are easy to fabricate. I have a Eclipse 2G, if you are more specific then I can help you even more.
Carlos
Carlos
