Dream Car
Old Feb 17, 2007 | 07:35 PM
ak47po's Avatar
Talking Dream Car
Ferrari 599 GTB Fiorano
My Dream car.
In Detail
price $255 000 USD
engine Aluminum Alloy V12
position 65 Degree V12
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl
fuel feed Multi-Point Fuel Injection
displacement 5999 cc / 366.1 cu in
bore 91.95 mm / 3.62 in
stroke 75.18 mm / 2.96 in
compression 11.2:1
power 455.6 kw / 611 bhp @ 7600 rpm
hp per litre Not Available litre
bhp/weight 361.97 bhp per tonne
torque 607.41 nm / 448 ft lbs @ 5600 rpm
redline 8400
drive wheels RWD w/F1-Trac Stability Control
front brakes Opt Carbon Ceramic Discs
f brake size 353 mm / 13.9 in
rear brakes Opt Carbon Ceramic Discs
r brake size 328 mm / 12.9 in
front tire size 245/40 19 Pirellli PZero
rear tire size 305/35 20 Pirellli PZero
f suspension Double Wishbones w/Delphi Magnetorheological Dampers, Coil Springs, Anti-Roll Bar
r suspension Double Wishbones w/Delphi Magnetorheological Dampers, Coil Springs, Anti-Roll Bar
weight 1688 kg / 3722 lbs
wheelbase 2751 mm / 108.3 in
front track 1689 mm / 66.5 in
rear track 1618 mm / 63.7 in
length 4666 mm / 183.7 in
width 1961 mm / 77.2 in
height 1336 mm / 52.6 in
transmission 6-Speed Manual or F1 Superfast
top speed 329.9 kph / 205 mph
0 - 60 mph 3.5 seconds
0 - 100 mph 6.9 seconds
0 - 1/4 mile 11.2 seconds
drag 0.336 Cd
designers Frank Stephenson (body)
Old Feb 17, 2007 | 07:37 PM
Blue By You Evo's Avatar
you dont even drive that car, the car drives you.
NY Evolutionary's Avatar
Wet dream car!!!!!!
alan678's Avatar
very nice....but i will stick to the Evo
Old Feb 17, 2007 | 07:38 PM
ak47po's Avatar
What do suppose the lights on the top of the steering wheel are for?
Old Feb 17, 2007 | 07:39 PM
pennjones's Avatar
That's a sweet Ferrari. As far as my dream car, it would probably have to be a Ferrari F430 F1 if I had no budget whatsoever.
Old Feb 17, 2007 | 07:40 PM
TechnoJunkie's Avatar
I like that but i would take the Enzo a yellow one like this
Old Feb 17, 2007 | 07:56 PM
purevibez's Avatar
was always a ferrari fan. my dream one would be the 550 marenello just like the one from bad boys 2. in white or silver. sexy!!!!!!!
Old Feb 17, 2007 | 08:02 PM
Those are shift lights! From yellow to red just like an F1 car!
Old Feb 17, 2007 | 08:03 PM
ak47po's Avatar
Thanks now i know.
Old Feb 17, 2007 | 08:05 PM
Vigo's Avatar
How much does it weigh?
Old Feb 17, 2007 | 08:06 PM
Thanks now i know.
No problem. BTW the !! were just to show exitement, not to dis.
Old Feb 17, 2007 | 08:10 PM
ak47po's Avatar
I knew that.
Old Feb 17, 2007 | 08:13 PM
tvbf1's Avatar
If that's your dream car!!!!!!!
Then KEEP ON DREAMING!!!!
J/K bro, doesn't hurt to dream.
LancerEVA06's Avatar
way too many buttons and lights for me... but sexy as hell.
