Evo ripoff
Old May 3, 2007 | 02:40 PM
Evozster's Avatar
whonda's SUCK!!!!!!!!!! i woldnt buy one if it was the last car on earth!!!!!!!
Old May 3, 2007 | 04:12 PM
randomevo's Avatar
Originally Posted by andysoo8284
Sad to say that car would run circles around the Eclipse on a road course.
I don't even want that to be true. I will re-read this article but....
I won't buy a honda, i won't buy a honda
Old May 3, 2007 | 04:45 PM
Seranin's Avatar
It's just too bad that it's fwd...beyond that, what a stellar car. 11.7:1 compression? that's nearing sportbike ratio. Though I suppose US gasoline couldn't satisfy that compression.
2800 lbs? That's amazing for a new car, if you think about it. Every year cars get heavier...hell, even the new miata is almost 2500 lbs.
As far as styling vs. the Evo X? I just don't see it. It has four doors and somewhat swoopy headlights...?
How about they trade two of those doors for a driveshaft and move the LSD to the back?
Old May 3, 2007 | 04:46 PM
mitsuozboi's Avatar
wow. I like the looks of that a lot. Unlike the 08 lancer which I think looks like a peice of trash. Go Honda.
Old May 3, 2007 | 05:46 PM
AznX TL's Avatar
mugen's had that wing for awhile, i think someone even put it on their evo because its like a mini-evo wing.
Old May 4, 2007 | 07:27 AM
randomevo's Avatar
ok so it sounds cool, but why are civics Hp #'s so high but the torque is so low
Civic Si 197HP 139lbs-ft
Type R 222hp 159lbs-ft
big difference no?
Old May 6, 2007 | 08:15 PM
Mr. Furley's Avatar
The 4 dr is ugly.
Old May 6, 2007 | 10:24 PM
Seranin's Avatar
big difference no?
There's only so much you can do with a naturally aspirated motor to improve peak torque numbers. Higher compression or more displacement. Aside from that you can only improve efficiency. And I'm sure you realize that the "high" peak horsepower numbers are simply torque at high rpm...right?
If your numbers are right I *am* impressed by the improvement from the Si to the Type R in peak torque.
Old May 6, 2007 | 10:37 PM
Vigo's Avatar
Too bad it's front wheel drive.
