2009 Subaru Impreza WRX specs... uh-oh
Old Jul 30, 2008 | 10:10 PM
DeeezNuuuts83's Avatar
http://www.autoblog.com/2008/07/31/2...on-sti-tweaks/
From Autoblog:
It's official folks. Those of you that picked up a 2008 Subaru Impreza WRX have been had. The road-going rally rocket gets an update for 2009 and with it comes a retuned 2.5-liter boxer four-pot producing 265 hp and 244 lb.-ft. of torque – a 41 hp and 18 lb.-ft. increase over the outgoing model. Power will be sent to all four wheels through a five-speed manual – the only transmission available -- with low-profile 225/25R17 summer tires replacing the 205/50R17 rubber of the 2008 model.
The suspension has been revised to include stiffer springs, uprated dampers, upper strut mounts cribbed from the STI and larger anti-roll bars fore and aft. The Aero package is no longer an option – it's standard – and includes an STI-inspired grille on both the sedan and hatch, while the five-door receives the STI's rear spoiler and underbody diffuser.
Impreza obsessives that ran out to buy a 2008 model might be miffed, but Subaru had to make adjustments to keep the WRX competitive, particularly with the Mitsubishi Lancer Ralliart becoming a serious contender in the turbo'd sedan segment.
From Subaru's press release:
Cherry Hill, NJ--Subaru is revving up performance and handling in its iconic All-Wheel Drive Impreza WRX sport compact for 2009, following the debut of the all-new model in 2008. Performance leaps to a higher level in the 2009 WRX thanks to a 265 horsepower turbocharged intercooled Boxer engine, retuned suspension and wider, lower-profile summer performance tires. WRX enthusiasts will quickly identify the 2009 models by the ST-type grille and standard Aero Package. The 2009 Impreza WRX comes with a 5-speed manual transmission.
New Impreza GT Model
Subaru is also introducing a new Impreza 2.5GT model for 2009, powered by a 224-horsepower turbocharged intercooled engine teamed to a standard 4-speed electronically controlled automatic transmission with SPORTSHIFT.
Both the more powerful WRX and the new 2.5GT are available as 4-Door and 5-Door models. As on all Subaru models, the Impreza WRX and 2.5GT models are equipped with Symmetrical All-Wheel Drive (two different versions – see page 2 for details.)
The goal of the 2009 WRX team was termed "Kyo-Ka" (translated from Japanese as "strengthening"). To achieve this goal Subaru engineers thoroughly revamped the performance character of the WRX for 2009. Gaining a larger turbocharger, along with a new larger-diameter exhaust and low-density catalyst for reduced backpressure, the WRX engine now produces 265 horsepower at 6,000 rpm and 244 lb.-ft. of peak torque at 4,000 rpm – significant increases from the 224 horsepower and 226 lb.-ft. in the 2008 version.
The Impreza WRX debuted an all-new platform for the 2008 model year, featuring a longer 103.1-inch wheelbase and an all-new double-wishbone rear suspension system. Revised suspension tuning for 2009 further bolsters WRX's street performance credentials. The standard 17 x 7-inch aluminum alloy wheels now wear 225/45R17 summer performance tires, compared to 205/50R17 all-season tires used on the 2008 WRX. The Vehicle Dynamics Control (VDC) stability and traction control system, which is standard on all Impreza models for 2009, helps to enhance the WRX model's road handling safety.
Standard Symmetrical All-Wheel Drive, which forms the common core technology on all Subaru models, gives the Impreza WRX a significant handling performance advantage over front-wheel drive competitors. Symmetrical All-Wheel Drive is a complete system comprised of the Boxer engine and the full-time power distribution system (varies by model and transmission). The aluminum Boxer engine and simple, symmetrical drivetrain layout help to lower the car's center of gravity, which in turn contributes to its handling characteristics.
The 2009 Impreza WRX employs a viscous coupling locking center differential that distributes torque 50:50 front/rear. Should slippage occur, this system transfers more power to the wheels with the best traction. The 2009 Impreza 2.5GT, like other Subaru models equipped with automatic transmission, uses a different version of the Symmetrical All-Wheel Drive system. An electronically managed continuously variable transfer clutch actively manages power distribution based on acceleration, deceleration, and available traction. This active torque-split system automatically transfers more power to the wheels with the best grip should slippage occur.
Suspension Re-Tuned For Sharper Handling
Subaru significantly re-tuned the suspension on the 2009 WRX, resulting in sharper turn-in and more responsive handling overall. Front upper strut mounts are adopted from the STI. The front spring rate is increased from 26.5 N/mm to 38 N/mm, and the rear spring rate is increased from 24 N/mm to 34 N/mm. Diameter of the stabilizer bars is also increased, from 20 mm to 21 mm in front and from 15 mm to 16 mm in the rear. Suspension damping has also been re-tuned. Notably, the new, stiffer suspension tuning did not require any further reinforcement of the inherently strong Impreza body structure.
Because the wider tires used on the 2009 WRX give more kickback than those on the 2008 model, a new damper valve was added to the steering gearbox to ensure a smooth and high quality steering feeling.
The Impreza WRX chassis is designed for improved rigidity and ride comfort and employs high-tension steel at key structural points. In addition to providing a basis for more responsive handling, the double-wishbone rear suspension that debuted in the new-generation Impreza models enables a smooth ride quality as well as decreased road noise for a quieter cabin.
The new-generation design results in a lower overall weight for the body while the longer wheelbase allows for improved ride dynamics, more interior room and reduced levels of noise, vibration, and harshness (NVH). In addition, the new chassis improves crash-worthiness and provides a stiffer platform for crisper handling.
Placing the engine slightly lower in the chassis than in the previous-generation Impreza models helped lower the center of gravity in the new Impreza platform, enhancing steering response. With the Subaru Dynamic Chassis Control Concept (DC3), Subaru optimized all elements of the Impreza's chassis to deliver a better balance of handling response, ride quality, quietness and overall traction performance than offered by competitive vehicles. (See "Performance" section of this press kit for further details.)
New WRX Aero Body Styling
On both 2009 WRX Sedan and 5-Door models, a new STI-type grille carries the WRX badge. Both models get a sharpened new look from the standard Aero Package, which was formerly part of the optional WRX Premium Package. Both body styles also feature front and rear under-bumper spoilers and aerodynamic side ground effects. The sedan has a low-profile rear trunk spoiler, while the 5-Door adopts the WRX STI rear spoiler and a rear diffuser. The rear garnish panel between the light clusters is body color on the 5-Door and chrome on the sedan.
Other distinctions between the two models continue as before, including clear rear tail lamp lenses for the 5-Door and red lenses on the sedan. The 4-Door features dual tailpipe outlets, while the 5-Door uses a single, larger outlet (stainless steel on Premium Package.)
Rally-Inspired Interior
The WRX interior introduced new comfort and spaciousness for 2008, and for 2009 it gains new WRX-exclusive carbon black checkered upholstery accented by red stitching. The standard tilt and telescoping leather-wrapped steering wheel is accented by red stitching and standard aluminum-alloy pedal covers now include the driver's footrest.
Performance-design front seats integrate the backrest and head restraint into a single structure. The sporty instrument panel features electroluminescent gauges, similar to the WRX STI. As in the WRX STI, the indicator needles sweep the gauge faces upon engine startup for a sporty effect. The WRX Premium Package gains a power moonroof; other contents carry over, including the 10-speaker audio upgrade with auxiliary input jack, projector-beam fog lights, dual-mode heated front seats, heated exterior mirrors and a windshield wiper de-icer.
The compact layout of the double-wishbone configuration helps to minimize intrusion into the cargo area, providing a wider and deeper luggage compartment. On the 5-Door WRX, the wide and flat load floor can accommodate two Tour-size golf bags with the rear seat backs in the upright position. In the WRX sedan, which is 4.5-inches longer than the previous-generation Impreza sedan and 6.5-inches longer than the new 5-Door models, the extra space provides for a larger, deeper trunk that can accommodate three Tour-size golf bags. In all WRX models, a 60/40-split folding rear seat further boosts cargo capacity and convenience.
Advanced Yet Easy-To-Use Technology
The available navigation and information center in Impreza WRX is the focal point of the center console. The navigation screen is located at the top of the dashboard for improved visibility and ease of use. With the navigation system, the center console provides an input for MP3 players as well as RCA-type video jacks that can accommodate portable gaming devices. These can be displayed on the navigation screen when the vehicle is parked.
Impreza models come pre-wired for XM® or SIRIUS® Satellite Radio. Both the standard and optional Impreza audio systems feature the Radio Broadcast Data System (RBDS) that can display a variety of information, including a song's title and artist. The standard WRX audio system features an AM/FM stereo with single-disc CD player and four speakers.
The WRX Premium Package adds an AM/FM stereo with 6-disc in-dash CD changer featuring MP3/WMA file capability. Occupants enjoy powerful sound from 10 upgraded speakers (six in the front doors, four in the rear doors) and SRS® Circle Surround Sound. Also with this package, the steering wheel adds audio system switches. An auxiliary audio input jack enables connection of an iPod or MP3 player.
The optional Satellite Radio and Navigation package for the WRX integrates the Audyssey MultEQ audio enhancement. Used in high-end home theater systems, Audyssey MultEQ creates the optimal sound experience for passengers in each seat position by tuning equalization that corrects for time and frequency response. The navigation system itself presents major functions through an intuitive, easy-to-use touch screen interface. This option also includes Bluetooth® hands-free wireless capability (requires accessory kit.)
Safety Technology
The new-generation Impreza models are built upon the proven Subaru Ring-Shaped Reinforcement Frame body structure with front and rear crumple zones. All Impreza models for 2009 feature a 4-wheel disc Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist. (The WRX and 2.5GT models have larger front brakes than other Impreza models.) All seats provide 3-point seatbelts (height-adjustable for outboard positions), and the front seatbelts have electrically triggered pre-tensioners and force limiters.
Side-curtain airbags are standard on all 2009 Impreza models. The Subaru Advanced Frontal Airbag System (SRS) features front seat side impact airbags and a driver's side front airbag that deploys according to the driver's proximity to the steering wheel, as measured by a sensor on the seat track. In the passenger side front seat, a sensor module detects weight – first determining if it is occupied, and if so by a child or adult – to control airbag deployment. As part of the system, the dashboard features an "Airbag" indicator light.
Old Jul 31, 2008 | 06:27 AM
sleeper3's Avatar
Repost: https://www.evolutionm.net/forums/sh...d.php?t=358328
Although this thread does serve as official confirmation from Subaru.
You guys didn't think Subaru was going to just sit idle as the Ralliart is being rolled out?
Here are some pics from that article:
Old Jul 31, 2008 | 06:31 AM
CAD EVO's Avatar
Originally Posted by sleeper3
Corolla S
I like the hatchback better
Old Jul 31, 2008 | 07:22 AM
evo_z's Avatar
Polished turd? Kudos on making the WRX more powerful but exterior wise it looks like s***.
Old Jul 31, 2008 | 07:26 AM
MR.Evo.06's Avatar
Looks like they took styling cues from Suzuki
Old Jul 31, 2008 | 07:29 AM
06MR6's Avatar
Go Suzukaru!!!
Old Jul 31, 2008 | 07:34 AM
VincentX's Avatar
It's not just more powerful it handles better too.
The color of the WRX in those pictures is nice.
Old Jul 31, 2008 | 07:38 AM
kim.ry's Avatar
ugly *** $hit.
Old Aug 2, 2008 | 11:00 PM
detroitmuscle's Avatar
wtf it still looks ugly...what exactly did they do exterior-wise?
Old Aug 3, 2008 | 09:52 AM
fromWRXtoEVO's Avatar
Subaru is doing that just to compite with the Ralliart.
Carlos
Old Aug 3, 2008 | 01:21 PM
Wayne99gsr's Avatar
Im not a STi hater but god damn, thats one ugly car.
Old Aug 3, 2008 | 02:04 PM
ThunderOZ's Avatar
I wonder if they'll bump up the STI hp and trq as well...
Old Nov 7, 2008 | 01:46 PM
mmartahus's Avatar
looks like the 09 wrx would destroy the 09 ralliart on the track, the specs and performance numbers aren't even close
Old Nov 10, 2008 | 10:13 AM
ducker's Avatar
The new wrx looks like a offspring of a Suzuki and a Kia.
Old Nov 12, 2008 | 02:46 PM
LeeC's Avatar
+1 to that
