Pagani Zonda R
Old Jun 24, 2009 | 05:40 PM
ak47po's Avatar
Exclamation Pagani Zonda R
General specifications
Country of origin Italy
Numbers built N/A
Produced in 2009
Introduced at 2009 Geneva Motor Show
Body design Horacio Pagani
Engine
Configuration AMG / Mercedes-Benz 60º V 12
Location Mid, longitudinally mounted
Construction light alloy block and head
Displacement 5.987 liter / 365.3 cu in
Bore / Stroke 80.2 mm (3.2 in) / 98.0 mm (3.9 in)
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel Injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body carbon composite monocoque with carbon composite bodypanels
Suspension (fr/r) double wishbones, pull rod actuated coil springs, Ohlins adjustable shock absorbers, anti-roll bar
Steering rack-and-pinion
Brakes carbon ceramic ventilated discs, all-round, ABS
Gearbox 6 speed Sequential
Drive Rear wheel drive
Dimensions
Weight 1070 kilo / 2358.9 lbs
Length / Width / Height 4774 mm (188 in) / 2014 mm (79.3 in) / 1141 mm (44.9 in)
Wheelbase / Track (fr/r) 2785 mm (109.6 in) / N/A / N/A
Performance figures
Power 750 bhp / 560 KW @ 7500 rpm
Torque 710 Nm / 524 ft lbs @ 5700 rpm
BHP/Liter 125 bhp / liter
Power to weight 0.7 bhp / kg
While we certainly cannot say the Zonda F lacks performance figures, driving around the Nürburgring in 7:32 and achieving lateral G forces of almost 1.5 G, it is however a road car, easy to drive, intuitive and setting the benchmark for comfort, safety and lightweight. Paired with a quality finish and the attention to detail this made the Zonda F one of the most desirable supercars resulting in the 25 Coupé models being sold out in record time. This did not seem to fulfil the requirements of our most demanding customers, who adore the weekend drive on a racetrack. The spark has been set by an Italo-American customer, enthusiast and already proud owner of 3 Zondas. He describes the project this way: "The thought has been on my mind for quite some time, but I am not interested in racing".
The Zonda R is born with full liberty. The target: the ultimate performance at the racetrack without any implications of rules, except for safety, where no compromise is allowed. In September 2006 the first drawings were ready, but it was crucial to have the support of Mercedes-AMG for a high revving engine with a power output of 750hp, dry sump, light and with a low centre of gravity. The basis was the self supporting engine of the mighty CLK GTR, which has dominated the GT championships. Eve at constant racing pace the engine would have to cover over 5.000 km before servicing. The challenge has been accepted without hesitation. The Zonda R is a car designed from scratch, with only 10% of the Zonda F components to be carried over. The suspension forged in Avional, a new Pagani six speed transversal sequential gearbox, carbon fibre monocoque, aeronautical four pump fuel tank are only part of the equation.
The wheelbase has grown by 47mm, the overall length by 394 mm and the track is increased by 50mm. The bodywork and aerodynamics have been studied to offer maximum downforce. Even though built for the track, the project would not have received kick off, if the quality and finish of the car and its details was not up to the level of the Pagani road cars. One of the first cars to be delivered however will be kept in a living room, designed by Pagani and built with the same materials as the Zonda F, beautifully textured carbon fibre, avional, titanium, inconel and other state of the art materials. Additionally it will feature a bespoke HiFi System that will allow the customer to listen to the sound of this car at Le Mans and the Nürburgring. The Pagani customers who have ordered the Zonda R will be relieved of almost 1.2 million + taxes.
The engine is built by the racing specialists at Mercedes AMG, where the championship winning DTM cars are born, as well as the CLK GTR, probably the most devastating and effective weapon ever to compete in the GT series. From it's engine the Zonda R borrows the basic architecture including an ingenious dry sump allowing a low centre of gravity. This self-supporting engine with 750 hp at 8000 rpm and 710 Nm of torque carries a lightweight carbon fibre highperformance intake system, a racing multiple disc sintered clutch and Formula 1 style exhaust system, hydroformed in Inconel 625 and ceramic coated for optimal heat dissipation. The power unit combined with a 6 speed transversal manual sequential synchronised gearbox is designed to satisfy the most ambitious drivers.
The central carbon chassis will incorporate a roll cage and a rubber racing fuel tank with 4 fuel pumps and quick refuel filler like on GT race cars. The wheelbase has been increased by 47mm to offer the best stability. The front and rear subframes are brand-new, built to accommodate a new suspension geometry, produced in avional. The magnesium forged rims with central wheel nut and a quick pneumatic lifting system allows fast and effortless changes of the slick tyres.
The new bodywork has been honed to offer elevated downforce even in low speed corners. The longer front bonnet with flaps, closed underbody and the rear overhang with the adjustable rear wing and race derived diffusor translate into shattering aerodynamic efficiency and will let you experience cornering speeds beyond imagination. The car displays and logs information about the amount of dowforce that the car is generating at each moment. Combined with the adjustable wings you can easily find the best setup for each track.
The interior is designed to accommodate the driver and passenger in bespoke seats, built to offer the best support, when the G-forces from the vehicle dynamics come into question. The Digitek instrumentation provides the essential information and a sophisticated telemetry allows through a variety of sensors to monitor every single component of the car.
Old Jun 24, 2009 | 05:46 PM
LOVEBOOOST's Avatar
HOLY **** THATS ALL I CAN SEE IS WOW
Old Jun 24, 2009 | 05:50 PM
ray3328's Avatar
wow! that's sick!
Old Jun 24, 2009 | 05:52 PM
boostedtres's Avatar
i am in love. the f was always one of my fave cars, this just blew that outa the water. nice find
Old Jun 24, 2009 | 06:25 PM
yahu's Avatar
I don't know why they didn't go with a CF windshield or CF tires though. Pussays!
Seriously though, the Zonda R is buh-dass.
Old Jun 24, 2009 | 09:24 PM
Drive02Lancer's Avatar
the tires don't look real, and if the tires aren't real, than the whole car isn't real. (mock of XXX quote from Vin Diesel, lulz)
Amazing looking car.
Old Jun 24, 2009 | 09:28 PM
xi's Avatar
xi
Holy ****! Those paddle shifters are huge!
Old Jun 24, 2009 | 09:31 PM
redleg225's Avatar
Zonda F is my favorite street Zonda. For the track, this thing!
Old Jun 25, 2009 | 12:41 AM
pnoy_RA06's Avatar
woooowwwww................................my mind jus like, exploded. thats one fine sexy car.
Old Jun 25, 2009 | 12:48 AM
Evolution IVGSR's Avatar
WHAT A WIN AMAZING LOOKING CAR AND WILL BE ONE TO REMEMBER
Old Jun 25, 2009 | 12:58 AM
Clipse3GT's Avatar
All I see is a sea of carbon... true race car.
Old Jun 25, 2009 | 01:01 AM
Just found this I would **** MY SELF if I saw this on the street Enjoy the sound
http://videos.streetfire.net/video/P...ign=newsletter
Old Jun 25, 2009 | 07:06 AM
TheBlueBlur's Avatar
Old Jun 25, 2009 | 12:09 PM
Ashtony's Avatar
Beautiful car, I wish i had one im my garage. I wont even drive it.
Old Jun 25, 2009 | 01:21 PM
WestSideBilly's Avatar
El Jefe
I think someone armor-alled the tires.
That aside, DO WANT!
