CAn you drop a Evo engin into a GSX?
Old Nov 11, 2003 | 10:57 PM
David21186's Avatar
I have a friend thats looking into buying a used car, and hes going to look at this 95gsx tomorrow. So i just want to know if it would be possible to drop in a 4G63, and would it be worth it?
EDIT: an evos 4G63
Old Nov 11, 2003 | 11:00 PM
bobaab's Avatar
GSX comes with the 4G63 engine. it just has little internal differences.
Old Nov 11, 2003 | 11:04 PM
Racer1's Avatar
The gsx already has a 4g63 in it. As for dropping in the current 4g63 from the evo I don't think the tranny would line up because the engine was turned 180 degrees after the 2g eclipes's.
Old Nov 11, 2003 | 11:17 PM
Evoandy's Avatar
the GSX has a 7 bolt 4g63... 7 bolt 4g63s= teh suck. If you can find a way to make the evo engine and tranny work, you could make alot of money in the DSM community getting those engines into their cars...
Old Nov 11, 2003 | 11:37 PM
David21186's Avatar
what if i get both an evo7 4G63 and the trans????
Old Nov 11, 2003 | 11:38 PM
David21186's Avatar
Part number on Engine 4G63 CT7292
Old Nov 11, 2003 | 11:42 PM
bobaab's Avatar
the evo7 and 8 engine and transmission are the same, evo 6 and before are the same.
evo7 and 8 = CT9A
Evo6 under = CN9A the only thing i rememebr is that the piston, piston rod are differnt in the two..im guessing the layout of the engine and transmission are the same tho. someone correct me if im wrong
Old Nov 12, 2003 | 01:04 AM
UltimateTSI's Avatar
Why doesnt your friend just get a JDM 6-bolt from a Galant VR-4 or an EVO 3(in which both would fit)?
They are still very powerful, but not as powerful as the EVO 7 4g63 because of better internals and bigger turbo. The one from a Galant usually comes with a small 16 turbo, whereas the EVO comes with a Big 16G turbo.
Old Nov 22, 2003 | 12:30 PM
Lan Evo's Avatar
Anything from EVO IV - VIII would be unlikely to fit into that car.
The DSM's 4G63 shares the same engine orientation with the EVO I-III (CD9A and CE9A chassis) 4G63. You will find that it is less likely that you can find parts for them since they're at least 8-9 year old cars.
I would suggest to build up your existing engine instead of getting a JDM 4G63. That's my thought
Old Nov 22, 2003 | 01:22 PM
Street Surgeon's Avatar
Good lord....
Evo's I, II, and III motors will fit in directly, any evo motor after that faces the OPPISITE DIRECTION so it won't work without SUPER customization.
7 bolts aren't bad @ all, their stock rods are a bit slimmer than their 6bolt counterparts, but who cares about stock anyway? If you're building a motor you would replace the stock rods! Also, no one would shell out bucks for an EVO VII or VIII motor?!? I'm sure they would cost upwards of 3 to 4k, and for what?!? A 270 to 300ish hp 4G63?!? Heh, you can get that with a stock motor and a 16G!
shane4840
Jan 12, 2014 02:35 PM
tellme718
Nov 8, 2012 04:18 PM
4g63girl
11
Mar 19, 2012 09:38 PM
4g63smokinall4s
Feb 22, 2011 07:52 PM
iLLiVo
16
Apr 11, 2009 08:54 PM
