Insane Speed 1200whp Supra Build!!
Engine:
Built 3.4 Stroker
Crower Forged Crank
Carrillo H-Beam Rods
Carr Rod Bolts
CP Coated Pistons 9/1
ACL Race Bearings
ARP Main Studs
Billet Main Caps
Insane Speed CNC Race Head
Ferrea stainless steel valves Intake and Exhaust +1mm oversize
Shimless buckets
Ferrea bronze valve guides
Ferrea Dual Valve Springs
Ferrea Titanium Retainers
Ferrea seats
ARP L19 Head Studs
Cometic Head Gasket
Unorthadox Racing Cam Gears
GSC Stage 2 Cams
Polished Mid Pan and Oil Pan
Polished TRD Motor Mounts
Greddy Chrome Oil Cap
Polished Billet Shock Arm
Power Enterprises Timing Belt
Power Enterprises Accessory Belt
Billet Tensioner
ATI Crank Pully
Polished TTC Idler Pully
Polished Unorthadox Racing Billet Pullies
TTC Polished Brake Cap
TTC Polished ABS Relay Cover
New Engine Harness
Engine entirely stripped, holes welded, brackets ground, painted + cleared
Fabricated Sheet Metal Intake Manifold
Accufab 90mm Throttle Body
Turbo + Exhaust:
Insane Speed coated turbo header T4
Tial 44mm wastegate
GT4508R turbo (polished and coated) T4
Aluminum cold air intake
AN Breather Kit
K+N Race Filter
Modified water neck
Boost Logic 4 inch stainless coated downpipe
Boost Logic 4 inch stainless exhaust
Tial BOV
Tial Wastegate
Cooling:
Koyo Polished Aluminum radiator
Polished Billet Radiator Tie Downs
4 inch race Intercooler
4” polished intake piping
Polished Upper and Lower Intercooler Straps
TRD Thermostat
Upper radiator hard pipe polished
Lower radiator hard pipe polished
Upper radiator cooling plate chromed
Radiator Mini plate chromed
Aluminum Overflow can
Trans + Clutch:
V160 6-Speed Transmission
RPS Triple Carbon Twin Disc clutch
RPS Lightweight Flywheel
Driveshaft Shop ProSeries Driveshaft
Driveshaft Loop
TRD LSD
TRD Trans Mount
CnC’d Aluminum shifter bushings
C’s Short Throw Shifter
Fuel System:
TTC Performance Billet Triple Denso Pump Hanger
Triple Denso 255 pumps
Injector Dynamics 2000cc Injectors
Billet Fuel Rail
Aeromotive Fuel Pressure Regulator
Custom AN Fuel Lines
Suspension:
TRD Sway bars Front + Rear
Cusco carbon rear strut bar
Cusco carbon front strut bar
KW V3 coilovers
Billet Subframe mount kit
Electrical:
HKS FCon V-Pro Engine Management
HKS DLI Twin Power Ignition
AEM Boost Gauge
Defi Water Temp + Oil Pressure Gauges
FJO Wideband
TRD 10K Tach
Optima Trunk relocated battery
Brakes:
Slotted front + rear Rotora rotors
Hawk brake pads
Goodrich Stainless brake lines
Wheels + Tires:
CCW Classic Black 18X10 front
CCW Classic Black 17X11.5 rear
Mickey Thompson ET Street Drag Radial (315/35/17)
BFG Gforce ZR front (265/35/18)
Interior:
Toyota Carbon JDM Steering Wheel
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet
New Factory OEM mats
Factory Black Leather seats
Exterior:
Clear Signal Markers
Clear Side Markers
3M Clear Bra
Built 3.4 Stroker
Crower Forged Crank
Carr Rod Bolts
ACL Race Bearings
ARP Main Studs
Billet Main Caps
Shimless buckets
Ferrea seats
ARP L19 Head Studs
Cometic Head Gasket
GSC Stage 2 Cams
Billet Tensioner
ATI Crank Pully
New Engine Harness
Turbo + Exhaust:
Tial 44mm wastegate
AN Breather Kit
K+N Race Filter
Modified water neck
Tial BOV
Tial Wastegate
Cooling:
TRD Thermostat
Trans + Clutch:
Driveshaft Loop
TRD LSD
TRD Trans Mount
Fuel System:
Billet Fuel Rail
Suspension:
KW V3 coilovers
Electrical:
AEM Boost Gauge
FJO Wideband
TRD 10K Tach
Brakes:
Hawk brake pads
Wheels + Tires:
Interior:
10% Tinted Windows
New Carpet
Exterior:
Clear Side Markers
3M Clear Bra
Exceptionally nice, wow.
But how come you left brakes all but neglected? With all that work & you're still running stock calipers/ rotors? I don't imagine that even the high end front BBK's would be more than $2,500 & it's performance benefits would be astounding. Esp, since you now have 1200+hp & you're trying to stop on 325hp brakes.
I agree with you, unfortunately, you can only install what the customer is willing to pay for. At least upgraded pads, rotors, and lines help significantly.
