730 BHP JUN S15.. Assembled in Western Australia.
Old May 30, 2004 | 03:36 AM
rexhunta's Avatar
Okay Guys, for the Fellows who love the S15s.. heres another out of the woodwork...
Speedworks WA have made this, ( www.speedworks.com.au ) and yes, that figure is at the rears.. and its a fully registered streetcar..
The only difference it runs from normal street tune to Dyno Comp.. is they change the T517s.. to a T88.. uh huh.. serious ****..
Okay, Time for the Specs on this baby !
VECHICLE SPECS
Vehicle Type
Nissan Silvia S15 Spec-R
Engine Type
SR-20DE(T)
Total Displacement
2200cc
ENGINE SPECS
Stroker Kit - JUN 2.2L Stroker Kit
Camshaft - JUN Camshaft Kit INT 66(264)-11.5/ EXH 66(264)-11.5mm
Valve Spring - JUN Valve Springs
Valve Retainer - JUN Titanium Valve Retainers
Head Gasket - HKS Metal Head Gasket (1.2mm)
Piston - JUN Super Piston
Connecting Rod - JUN Super Connecting Rods
Crankshaft - JUN Full Counter Crankshaft
Turbo - TRUST T517s
Wastegate- TRUST
Boost Controller - Blitz SBC-ID Electronic Boost Controller
Intercooler - TRUST 2-Layer
Intake Manifold - JUN GT-Surge Tank
Exhaust Manifold - JUN Stainless Manifolds
Blow-off Valve - Blitz Super Sound
Muffler - Nismo N1
Air Filter - Blitz LM-Type
Oil Cooler - TRUST 23 Layer
Radiator - Sard Radiator Hoses
ECU - JUN S15
Fuel Injector - Nismo 740cc
Fuel Pump - Bosch (x1)
Fuel Regulator - Sard
Spark Plugs - GReddy
Clutch - Cusco Super Single
JUN Lightened Flywheel
Transmission -Standard
Diff Ratio 4.375
LSD - Cusco1 Way
Others Cusco Breather Tank
Odyssey 1500 Dry-Cell Battery
Nismo Engine Mounts
SUSPENSION & WHEELS
Brake Caliper - Brembo 4 Pot Calipers (Front)
Brembo 2 Pot Calipers (Rear)
Cusco Brake Master Cylinder Stopper
Brake Rotor - A'Pexi 330mm (Front)
Brake Pad - Endless
Earl's Braided Brake Lines
Suspension - HKS HyperMax Damper Coil-Overs
Nismo Power Brace System
Nismo Bushings (Full)
Cusco Pillow Ball Tension Rods
Cusco Adjustable Rear Upper Arm
Cusco Adjustable Rear Toe Control Rods
Strut Tower Bar Cusco Front Struts
Cusco Rear Struts (Carbon Fibre)
Sway Bar - Cusco Stabiliser Bar (Front & Rear)
Rims - Yokohama Advan RG Rims 17x7.5 (Front)
Yokohama Advan RG Rims 17x8.5 (Rear)
Tyres - BridgeStone Potenza RE540S 215/40/17
BridgeStone Potenza RE540S 235/40/17
EXTERIOR
Bodykit --
Rear Spoiler - Cusco GT-Wing
Others --
INTERIOR
Seats --
Steering Wheel --
Gear Knob --
Gauges --
Turbo Timer - Blitz
Pedals --
Others - Blitz Power Meter
Nismo Shoulder Pads
Hrmm, Speedworks have also done 2 evos.. check our thier site for more info
