Evo vs M3
Old Jul 31, 2004 | 10:52 AM
MaxR's Avatar
i raced an new m3 with my stock evo on 94 octane. two rolling starts from 30 to 70. it was a push.
Old Jul 31, 2004 | 11:01 AM
SterlingEvo's Avatar
after about $1500 in parts and tuning, I walked away from a friend's stock m3 from a stop, but then again I do the same to stock Evos
Old Aug 1, 2004 | 02:17 AM
awdmofo's Avatar
Originally Posted by Rez90
none as long as you can drive....
we took my cousins 03 m3 to the track last night...after 8 runs and 3 drivers the best time we could get out of it was a 14.6 at 95....the car was impossible to launch.
unless the guy in the M3 is a pro driver...chances are you can just slingshot by him out of the hole namely because you have AWD
95mph trap speed? something is wrong with your cousins M3. I can understand a bad launch giving you a bad ET but trap speed should still be 100+. You sure this wasn't an e36 M3? Stock for stock I would say the Evo and M3 have similar acceleration up to about 100mph or so. After that the M3 will start to walk away. That's stock though, with some bolt ons and tuning the Evo will eat the M3 alive!
Old Aug 1, 2004 | 02:44 AM
YellwTyper's Avatar
You gotta hold the traction control button for a bit longer to really disengage all computer aided controls... give that a try and see if that helps..
Old Aug 1, 2004 | 03:26 AM
EvoEightMR's Avatar
Are you guys comparing the M3 and the US spec Evo? Correct me if I'm wrong, I think the JDM Evo VII GSR or JDM EVO VIII MR will beat the M3 in a straight race. But I've never seen an EVO running against Ferrari or Lambo because there are modded M3s racing against one those supercars. I wish there was also a heavily modded Evo racing a Ferrari or Lambo.
Old Aug 1, 2004 | 04:05 AM
Sentinal's Avatar
Id put my money on Turbotrix Evo if they went up against any lambo or ferrari...
Old Aug 1, 2004 | 05:44 AM
JaReDbOy's Avatar
lol at 9.9 you'd better
Old Aug 1, 2004 | 07:56 AM
yo... Al's dynoflash car (for example, and anyone similar to it) will keep up with the Enzo in the 1/4... And most modded/tuned evos would keep up with production type ferrari's, like 355 and 360. They raced a 500hp Focus v. Lamborghini in Britain, and they were dead even... low 4 sec. to 60mph, mid 12's 1/4 which is what a lot of medium modded Evo's are running.
Old Aug 3, 2004 | 01:39 AM
typeR430's Avatar
i dont have trouble driving my car....u guys forgot about the "SPORT" button...and dont even compare $xxxx worth of mods vs ///M3 its a different class, if they cant drive the evo with $xxxx worth of mods, its not gonna make a difference, ur friend running 14.6 is a bit sad...i could pulls those times with my stock Integra
Old Aug 3, 2004 | 08:28 AM
BLiu's Avatar
With all due respect, the "Sport" button doesn't do squat for overall 0-60 or 1/4 times. It's just a remapped throttle curve so you are getting faster throttle response but the area under the curve is still the same. Don't believe the hype...
Brent
Old Sep 5, 2004 | 05:48 AM
Derek888's Avatar
Can someone name a list of mods needed in order to beat a e46 M3? Either from a stop or rolling start up to about 100mph, after that I dont care. Lately I see alot of e46 M3's wanting to race me but my car is still new so I cant do much but if I do race then I want to make sure I dont lose to a stock M3
Old Sep 5, 2004 | 06:32 AM
Sentinal's Avatar
If your a good driver you can beat them without any mods the 0-60 in the Evo is actually rated faster OEM than the M3 is by about 3 tenths of a second the quarter mile is about the same after that the M3 will walk away from you because they have much more top end. Your advantage will be from 0-100 in a stock Evo. You should be able to run neck and neck with them up to about 100 If you want to have a clear advantage over them just do a 3" turbo back exhaust and get the car dynoflashed or go with a stage 1 kit from vishnu either way you will spank a stock M3 with either setup
Old Sep 5, 2004 | 07:56 AM
imajinmyfx's Avatar
this guy that lives by my g/f use to have a red M3 and just today i past by and now theres a red evo there .... good swich.. haha
Old Sep 5, 2004 | 08:44 AM
MisterSpoot's Avatar
Actually, stock for stock, an S2000 can actually hang onto a stock E46 M3 at the track and never let go. I've done it out at Watkins Glen on a few occasions. The only thing is you can't make a single mistake. The M3 simply isn't nearly as quick in the corners as the S2000 was, though it would always catch up by the time the next turn came along -- so if you screwed up there, the M3 had you and you probably won't get back in front until the M3 makes a mistake.
An Evolution, granted if the driver knows what they're doing, should gain a good 3-4 seconds and change on an M3 every lap around the Glen.
Old Sep 6, 2004 | 05:35 PM
IS2000's Avatar
I ran an e46 M3 with bolt-ons from 80-130mph. My car was clearly faster, but the M3 wasn't much slower either. You will need at least 300awhp to hang with the M3 on the freeway. From a stop, a stock EVO should give the M3 a good run.
