Tail light problem
Old Oct 23, 2002 | 08:54 AM
WannaRace's Avatar
Angry Tail light problem
Whenever it is humid, my rarely used Eclipse Euro tail lights get fogged up on the inside and it looks really bad...Is there any way to prevent/stop this from happening? Please help..
Old Oct 23, 2002 | 08:59 AM
ryancb's Avatar
prob wernt installed right friends civic does same
Old Oct 23, 2002 | 09:00 AM
WannaRace's Avatar
Maybe cuz I installed them?
Well everything is in place, tight and secure...Something that I can't tell/see maybe?
Old Oct 23, 2002 | 10:02 AM
diesel_fan's Avatar
Do the plastic bulb bases have little o-rings or gaskets on them to help seal them? You might want to check your other bulbs as well to see if they're not sealing well when installed in the bulb opening. If there's a gap, you're going to get moisture in there.
A much more remote possibility is that there's a hairline fracture along the seam where the colored part of the lens assembly is glued to the back plastic part. If it persists you may want to take out all the bulbs and pull the assembly off the car to have a look.
I had an old Ford that did this. I pulled it off and filled it with distilled water and let it sit. Sure enough water was seeping out from a lens edge that was separating. I dabbed some silicone outdoor caulk along that edge (and all the others) - problem gone.
Old Oct 23, 2002 | 10:08 AM
WannaRace's Avatar
I'll check it out.. Thanks
Old Nov 28, 2003 | 10:37 AM
(Lancer)'s Avatar
My friend and I are trying to figure out how to take the back pieces off of his 95 Eclipse right now to install his euros and are kinda stuck. Could someone post help on how to unattach the stuff. One side just came off easily by pulling, but the other we broke the thing off by pulling way too hard. Brute force I guess We'll probably already have it done by the time someone posts, plus I didn't bother to check how old this thread was, but who knows...
OneCrzyEvo21
May 24, 2016 10:58 PM
blazersman
27
Feb 14, 2013 05:29 AM
EvoJoeIX
Feb 15, 2011 05:21 PM
SIMSSEGA
10
Feb 27, 2005 07:34 PM
DA-4BANGA
Jun 6, 2004 07:09 PM
