JDC Premium COP Ignition System with NGK GT-R Coils (Evo 4-9)
For SaleEngine - Electrical
Discount
15% Off
- Valid From Nov 18th 2018
- Valid To Nov 26th 2018
- Condition New
- Compatibility
| Make | Model | Year |
| Mitsubishi | Lancer Evolution | 1996 - 2006 |
JD Customs USA
2950 Fulbright Rd. NE
Cleveland, TN 37312
USA
Cleveland, TN 37312
USA
15% off for a limited time! Use code "JDCNEWCOP" at checkout.
Visit www.jdcustomsusa.com to order!We're excited to introduce the new JDC Premium Coil-on-Plug Ignition System! It utilizes R35 GT-R Ignition coils by NGK to withstand upwards of 1000+ horsepower without needing a pesky CDI box! The stock coils on the GT-R are known to handle 1000whp+ without needing an upgrade and the NGK coils are an upgrade over stock coils! This system will plug straight into your factory wire harness without any modifications. It's a simple, 10 minute installation.
These systems have been tested on multiple Evo's for over a year and show great reliability as well as performance. This is meant to be a one time buy for all levels of performance.
The JDC Premium Ignition System is the only Ignition system your Evo will need throughout its entire lifespan, starting with bolt-ons all the way up to a straight drag car pushing 1000whp! Forget the need for a problematic CDI system. This COP System can do it all!
Don't waste your money on overpriced systems when the JDC Premium COP uses UPGRADED coils that outperform the Hitachi coils. Get yours today starting at only $509.99! That's a steal compared to the competition.
Features:
- Brand new high performance NGK coils (outperform OEM Hitachi)
- Beautiful solid carbon fiber, Titanium, or Satin Black mounting plate
- Designed for cars making 300whp up to 1000whp+
- High quality military spec heat sleeve protector rated to 428degF
- Upgraded (thicker) 16g tefzel military spec wire, rated to 393degF
- Plug and Play (no assembly required)
- Greatly reduce or eliminate partial throttle bucking
- Better idle quality
- Quicker and easier start especially in colder weather with E85
- Run more boost without spark blowout issues
- Run more gap for better fuel burn and increased mpg
- Plugs last longer due to less fouling
- Plug changes take minutes less
- No problem prone CDI Boxes
- Non corrosive stainless steel hardware
- Assembled JDC Premium Coil-On-Plug Ignition System
- Completely sealed waterproof wire harness
- Stainless steel mounting Hardware
- 15 amp fuse
- Installation instructions & warranty information
- NGK coils- 2 years
- Wire harness & mounting plate- lifetime (to the original buyer)
- We suggest setting the factory dwell time at 3.4ms @14v to help keep the coils cool.
- These upgraded coils can support up to 4.5ms which would allow you to run an even larger spark plug gap for better combustion, which could support even more horsepower.
- For example, 3.0ms @14v has easily supported 870whp on a mustang dyno.
- Saturation that could shorten the life of the coils and cause premature failure would be around 5.5ms @14v.
Please allow an average of 1-3 business days for your order to ship. (This is an estimated time and may take longer depending on quantity of orders and availability of parts.) Visit our website for more information or give us a call.
