Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
Another F'ed up tune from "The other shop"
Old Jul 3, 2008 | 06:10 PM
Silver06evo9mr's Avatar
So show and i did 2 logs on my car and pulled my maps. All my maps but the fuel one is the same as like 8 other people. Also on my two logs from about 5000k- 6500k or so i had like 7 7 7 7 8 8 8 8 9 7 7 7 7 counts of knock.
Show can post with some more details and maybe my logs.
Post your experience with this other shop and your tune cuz this is gettin old. Thank god Lonnie @ LMS and kreonic are gunna hook me with some new stuff soon.
"The other shop"
Old Jul 3, 2008 | 07:40 PM
dee_yamaha's Avatar
Was the knock you logged from the "Knocksum" field?
Did you do your pull on 3rd gear from about 2500 rpm to redline?
Sorry to hear about your knock, hope you get it fix or atleast reduce it to less than 3.
I been doing my logs and started tuning also with the Tactrix cable using Ecu Flash and logging data through Mitsulogger/(Zeitronix for WB/boost/EGT)
Happy Tuning!
Old Jul 3, 2008 | 07:41 PM
i did do the 2 pulls from 3rd gear 2500 to redline.
Old Jul 3, 2008 | 08:00 PM
dee_yamaha's Avatar
Try comparing your two fuel maps (high and low) are the cells similar to each other especially where it is registering knocks, then look into your timing and see the numbers on those RMP/loads...are the timing advance or retard.
Are the knocks consistent?
I'm sure Lonnie/Kreionic will hook you up! easy fix!
Old Jul 3, 2008 | 08:09 PM
Nesiop's Avatar
What is this Other Shop? The Shop CT? Junior is a pretty darn good tuner if this is who you're referring too.
Old Jul 3, 2008 | 08:10 PM
DarksideEng's Avatar
I think your problem is your revving the car too 5000k (5 Million RPM)
Old Jul 3, 2008 | 08:54 PM
chrisevo8's Avatar
that sucks dude. Charlie will fix your problem
Old Jul 3, 2008 | 08:59 PM
SASD209's Avatar
Admin Alumni
Why don't you stop being cryptic and post what you really want to say? We have an entire forum dedicated to this kind of post, it's located here:
https://www.evolutionm.net/forums/fo...play.php?f=176
Please be sure to read the rules and then feel free to post there. If you're not just trying to "stir the pot", then surely that would be the appropriate forum??
CLOSED////
SASD209
