Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Chicago Evo Immobilizer Help!
Old Mar 10, 2016 | 06:25 PM
gray9evo's Avatar
Do any of you guys in Chicagoland area have the tools and skills or know of someone that can disable the immobilizer on the ecu of an evo 9?? My car won't start and everything is pointing to it being an immobilizer issue. I will compensate whoever can do this for me. Please pm me if you can help!
Old Mar 10, 2016 | 08:18 PM
Evoryder's Avatar
How do you know it's the immobilizer? Many different things can cause the car to not start. Any stored codes?
Old Mar 11, 2016 | 05:08 AM
gray9evo's Avatar
My mechanic's words after he did a timing belt job and replaced the crank sensor :
I have finished the car but it still does not start – no spark or injector signal. I spent about 3 hours on it trying to determine the issue. I believe the problem is in the Immobilizer ECU. I went through the troubleshooting procedure and found that the Immobilizer light on the dash does not light up when the key is turned on. If I ground the wire that goes to the light, it does light up. The next step in the procedure is to replace the Immobilizer ECU. This needs to be programmed to the car which is something I cannot do. At this point you need to take the car to a shop or dealer to have this part replaced & programmed.
My car hasnt started for a couple months now. Car cranks but get no spark or fuel. I thought the new crank sensor would fix it but still nothing. Also already replaced exhaust cam sensor. No stored codes.
Old Mar 12, 2016 | 11:49 AM
turbotaloon95's Avatar
I've got ecuflash / evoscan and the tactrix cable, I might be able to help. I'm located in Bloomingdale.
Old Mar 13, 2016 | 09:13 AM
gray9evo's Avatar
PM sent
caevo8
West Region
Apr 29, 2012 01:21 PM
COBB Tuning
Jun 21, 2010 11:52 AM
youngblood90
Midwest Region
33
Feb 23, 2007 08:38 AM
ace_2822
Oct 16, 2006 06:36 PM
zupber4930
Midwest Region
10
Apr 29, 2004 03:27 PM
