PDA
View Full Version : Marketplace
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20
  1. WTB Evo shell,block,head Tri-state area
  2. S>Tactrix 2.0 OpenPort
  3. WTB Evo 9 long block tri-state!
  4. FS: Wicked White Evo9 hood
  5. FS: Complete set of suspension arms (whiteline bushings) and hubs from EVO9
  6. 17x8 rota grids with tires
  7. WTB: Spoolin up COP
  8. Looking for OEM Evo 8 Wing
  9. Stock Evo 8 Enkei Wheels/Tires
  10. Evo 7 Taillight (Passenger Only) Slightly Damaged
  11. WORKS exhale stealth exhaust
  12. 2012 EVO X Greddy BOV
  13. 2012 EVO X GSR FEAL 441 Coilovers with Swift Spring
  14. 2012 EVO X OEM Shifter Cage with Works Short shifter
  15. Evo x gsr oem used front axles $350
  16. ETS 3" HFC Test Pipe Evo X
  17. Looking for Varis Style Front bumper and Lip Version 1 style
  18. WTB ACD pump with tank, Evo 9 valve cover, mivec gear
  19. Thule Roof Rack System - 2008+ Lancer / Evolution X
  20. RARE - ARC Rainbow Ti spark plug cover - new
  21. 2006 Evo IX RS
  22. Oem and aftermarket evo 8 parts (garage clean out)
  23. Looking for Rear Brake Caliper. EVO 9
  24. gruppe M ram air evo 789
  25. Wtb HKS cam gears
  26. WTB Evo 8 built tranmission
  27. Evo 8/9 depo tail lights
  28. Ets v band down pipe
  29. WTB: Evo 8 wing
  30. Evo X Carbon Duct
  31. REXPEED JDM CARBON REAR BUMPER EXTENSIONS 2x2 Weave-ONLY FITS JDM REAR
  32. Tomei Exhaust Manifold Evo 8/9
  33. WTB: Stock size Speed density intake
  34. Act xtss mb018x
  35. Diamond black Volk TE37SL 18X9.5 +22
  36. FS: 1995 Lancer Evolution 3 - 686whp (video included)
  37. Brand new ACT XTSS clutch kit and Street Light Flywheel
  38. FP JB Oil Supply Line BRAND NEW
  39. OEM battery box / tray, OEM battery tie down and OEM battery insulation
  40. Tactrix Open Port 2.0
  41. WTB: Wicked White Side View Mirrrors
  42. Enkei stock Evo x wheels
  43. Enkei stock evo x wheels
  44. RPF1s
  45. G42-1200 turbo kit, JMF manifold , magnus , kelford
  46. Injen Cast Aluminum Intake &l IC Piping - Evo 8/9
  47. STM MAF Adapter and Filter Kit - Evo 8/9
  48. Spark Tech Pro CDI 14
  49. Evo8/ 2010+ Lsd Ralliart Rear Diff
  50. Evo viii 8 taillights tail lights For Sale
  51. 2010 Evo X SE, AMS built, 2.2L, 750R, ~510 whp
  52. WTB. Block bare/built WTB head bare/built
  53. AMS Remote Oil Pressure Sending Unit Line For 4G63 And 4B11 Engines
  54. 42 Draft Designs Oil Temp and Pressure Adapters - NLA
  55. Gruppe-S Gauge for 60mm gauges w/ HVAC stickers
  56. Bilstein/swift
  57. (WTB) Factory / Stock Evo 9 Down Pipe
  58. Evo X, HPDE prepped
  59. FS: Stock Evo 9 KYB Struts w/ Tien H Tech Lowering Springs
  60. Evo 8 AC compressor
  61. Stock Evo 8 Intake Manifold, Throttle Body, fuel rail, Intake with MAF
  62. Evo 8 Megan exhaust manifold, TurboXs BOV, Megan lowering springs
  63. Evo 8 Stock cams, Lifters and Cam gears
  64. Stock Evo 8 Suspension
  65. Stock Evo 8 Turbo, O2 Housing
  66. WTB: Evo IX Valve Cover
  67. WTB: Evo 8 rear adjustable camber arms
  68. Turbo Smart BOV Kompact
  69. Lancer Badges
  70. Gear Knob Sticker
  71. WTB AEM infinity or Haltech 1500
  72. Evo IX Short Block 2.3
  73. Looking for Kansai air box
  74. WTB Evo Titanium Brake Shims
  75. WTB: OEM EVO IX Gauges *or* instrument cluster - only need the black faceplates!
  76. Cusco rear strut bar type cb for mitsubishi evo 7-9 ct9a
  77. Titanium ARC strut bar , Ralliart shift console, cluster gauge s1 type
  78. ***PART OUT*** / 2003 EVO 8 / ***PART OUT*** / What do you need?
  79. Evo 8/9/10 garage clean out
  80. Wanted USED Evo 8/9 mustache bar alloy
  81. FS Haltec Elite 2500 Evo 9 PNP
  82. Wtb works exhale exhaust. Evo 8 9
  83. EVO 8, EVO 9, EVO 10 / OEM and Aftermarket Parts
  84. FS: EVOX ARC FMIC, ARC intake box, AMS high flow cat
  85. FS: Haltec Elite 2500 Mivec evo 9
  86. FS: Tial 50mm Bov
  87. Evo 9 Turbo and HKS HiPower Exhaust
  88. Evo 8/9 BBS stock wheels
  89. Ohlins DFV Evo 8/9 - Used
  90. Evo IX short block (bare)
  91. Fab house battery relocation kit
  92. Evo 8-9 APR Carbon pieces
  93. USED Evo 9 Headlights
  94. WTB Evo X Metal Valve Cover
  95. "RARE" 2004 Mitsubishi Lancer Ralliart Sportback - Turbocharged
  96. Sheepy turbo kit
  97. WTB - Every rear suspension & subframe bolt + brake shields + rear subframe mount
  98. WTB: BBY Complete Front Bumper and Hood / Evo 8 Headlights / Front Evo 8 Seats
  99. Evo 8 Cylinder Head - 2003-2005 4G63
  100. FIC 2150 High Z Injectors - Cleaned/Flow Balanced - With Pigtails
  101. Walbro TIA-485-2 F90000267 TI Automotive E85 In tank 450 Lph high pressure fuel pump
  102. FS: Tomei 270 cams Evo8
  103. WTB: Given Up Projects, Complete Evos or Wrecked Evos!!!
  104. Evo 9 OEM Mivec Cam Gear
  105. Evo 9 OEM Exhaust Cam Gear (not Mivec)
  106. Wtb evo 8/9 gas tank !
  107. FS: 3" Test Pipe / ETS O2 Dump
  108. GSC S2 Cams w/ HD spring & retainers (Evo 9)
  109. Sheepy turbo kit
  110. Looking for 18x9/9.5 wheels
  111. 3 Weisco Pistons
  112. Evo 8-9 Brembo Brake Calipers
  113. Evo mr or se wheels wanted
  114. Evo x bbs
  115. Greddy BOV for EVO X
  116. 2012 Evo X OEM Headlights
  117. WTB: Evo 8/9 front bumper
  118. WTB Evo 8 9 MR BBS Wheels
  119. BBK Full turbo
  120. Zeal Function Coil-Overs for the 2003 - 2006 EVO 8/9
  121. FS: (2x) Evo Oil Change - 5 Qts Brad Penn 10w-40 & OEM Mitsubishi Oil Filter
  122. WTB : MR Guage pack with oil temp sensor wire
  123. Side spats, side skirt extension, and splitter
  124. WTB Evo 5 speed transmission
  125. Cusco Carbon Fiber Rear Strut Tower Bar for the 03 - 06 EVO 8/9
  126. Volk VR.G2 17x9.5, 5x114.3, 30mm offset, Flat black, set of four, New
  127. 1000cc RC Injectors
  128. 2003 OEM catalytic converter.
  129. M10 x 1.25 Titanium GR5 Ti6Al-4V Studs for the FP Manifold to Turbo
  130. WTB: MIVEC Oil Feed Control Valve - Evo 9 (MD375473)
  131. FS: Clean 2006 WW EVO RS Low Miles!
  132. Pistons and V-band turbine housing
  133. COBB Accessport V3 Lancer Evo X 08-13 UNMARRIED
  134. WTB Left Front Door Lock Actuator
  135. STM Single Exit TBE 3K Miles
  136. Evo X LED taillights
  137. Fujitsubo cat back for Evo 8--9
  138. Wtb built tranny / or tranny gears
  139. WTB: Evo 8/9 Thule roof rack
  140. WTB: Evo 8-9 O2 Dump
  141. WTB Evo8/9 Power steering racks *Chicago land Area*
  142. Small Part out (SPARCO seat bases, OEM 4g63 crank, tail lights
  143. 2014 Mitsubishi Evolution GSR - leather heated recaros :)
  144. "Brand New" Right Side JDM Evo VIII HID Headlight Assembly
  145. Walbro 400, stock evo 9 cams, engine mount, crank pulley, flywheel, fuel pressure gau
  146. Evo 8-9 rods and pistons
  147. WTB Evo x final edition floor mats MZ360512EX
  148. Evo 8/9 Rods/Pistons, Injectors, Etc
  149. FS: (2) Enkei RPF1 17x8.5 +30
  150. Injectors, Down pipe, cam gear cover, spark packs
  151. Looking for AYC ACD pump
  152. Wtb afr aem gauge & engine mounts
  153. K&N 3.5'' RE-0920 Air Filter, New
  154. K&N 3.5'' RU-3130 Air Filter, New
  155. Mitsubishi Evo X OEM Turbo Outlet Gasket and Exhaust Manifold
  156. Evo X OEM Injectors Set and Injen SP Series Intake
  157. Evo 8/9 Air Intake Cleaner Box
  158. Mitsubishi Evo 7 JDM Parts For Sale Fits: Evo 8/9 (JDM Rear Bumper, Pair of Rims)
  159. FS: ADVAN RS 18x9 +29 with 255/35 RE71's
  160. FS: EVO X Brembo's, SS pistons, Track pads
  161. FREE! XSPOWER intercooler (Socal pickup only)
  162. FS: Enkei RPF1 17x9.5
  163. FS: Central NJ Evo AEM CAM GEAR $100
  164. EVO 8,9,10 parts
  165. ***PART OUT*** / 2003 Lancer Evolution VIII with 62k miles / ***NO DRIVE-TRAIN***
  166. EVO 8 and EVO 9 Parts (OEM and Aftermarket)
  167. OEM 5 Speed Center Console for the 2003 - 2006 EVO 8/9
  168. 5 Speed Installation Kit for the 2003 - 2006 EVO 8/9
  169. 2003 EVO 8 OEM Recaro Seats (Front and Rear) Blue and Black with only 62k miles of us
  170. 2003 - 2005 EVO 8 OEM MOMO Steering Wheel with the OEM Airbag
  171. 2003 - 2006 EVO 8/9 OEM Brembo Brake Calipers (Front and Rear) 62k miles
  172. VT: PB 2014 Evo X MR, Very Low Miles, Excellent Condition
  173. Girodisc Dust Boots (new)
  174. Almost NEW Enkei RPF1's 17x10 +38 with used Hoosier Tires mounted
  175. WTB: O2 Dump / O2 Eliminator downpipe
  176. J.D.M. Varis Carbon Fiber Hood for the EVO 8/9
  177. J.D.M. Varis F.R.P. Aero GT Fender Set for the EVO 7,8,9
  178. 2003 - 2005 EVO 8 OEM HID Headlights / 100% complete plug and play
  179. WTB catalytic converter, ecu, evo 9 trans harness
  180. EVO 8 Front bumper / Nose chop / JDM Varis Carbon Fiber Lip, Ducts and Canards
  181. Wtb: Oem evo x recaro seats
  182. 2003 EVO 8 Part Out / No drive-train / Let me know what you need
  183. Evo 9 Stock Enkei wheels w/tires
  184. WTB: Evo 9 OEM IAC
  185. WTB: Front fender liners
  186. T-case tail section
  187. Mitsubishi Lancer Evolution 1
  188. FS: Central NJ Evo AEM CAM GEAR $100
  189. FS: Central NEvo Brembo Rebuild Kit $100
  190. WTB: Oem oil cooler feed and return lines.
  191. GReddy BOV Type RS, needs new diaphram
  192. WTB RMR Lower Brace
  193. RRM timing controler
  194. Evo X - Chicagoland - Partout... ETS, Cobb, Enkei, TurboXs and more
  195. rs differential, Headstud Kit, Buschur Intake
  196. New rexpeed carbon fiber rear spats
  197. 2006 ww ix mr
  198. 272 HKS CAMS from a evo 8
  199. WTB: Evo 8 Stock Turbo/FP Red/ FP Black, Exhaust Manifold, Throttle Body Oem, C.O.P..
  200. WTB map cast vband manifold
  201. WTB Evo VIII/XI rear diff with axles
  202. Wtb/wtt: 05-06 tb
  203. WTB: evo 8/9 Enkies
  204. WTB Evo 8/9 in or near Carolinas
  205. WTB: TWM shifter cage
  206. FS: Evo 9 Ecu, ACD Ecu, Tactrix 2.0
  207. Evo 8-9 steering rack
  208. 2003 Evo 8 GSR just over 19,000 original miles. one owner. lots of mods.
  209. 08-15 OEM Evo X Aluminum E-Brake & Shift Knob
  210. Pistons, Turbo, Injectors, Crankshaft
  211. Sparktech CDI
  212. Evotuna's Tax Season Partout!!!
  213. Evo 8 block
  214. Evo x 2008
  215. 03 evo8 Complete factory, 12k original miles!
  216. Evo 8/9 fender braces
  217. Apexi RX6 Turbo kit wanted
  218. FS: NonACD Transfer Case (tcase t-case) 55k miles (CA)
  219. FS - Philly Area - Trunk Liner Pieces 2 pieces / Center Console / Blank Switches
  220. Looking for carbon headlight racing covers for evo 9
  221. Recaro seat back
  222. Skunk 2, fic 2150, full blown, fuel lab, hallman
  223. Brand new 6266 vband in/out ball bearing
  224. 2.4L long rod stroker
  225. Looking for a Fuel Tank JDM Evo 7/8/9
  226. 2011 Mitsubishi Evolution GSR
  227. ARC Intake Box, AMS UIP, JDM Amber Side Markers, and more
  228. North Dakota WANTED!!!
  229. Evo 9 ABS Clutch Pedal
  230. Clean Evo 9 Dash
  231. Need to buy evo 8 head
  232. FS: Brand new never opened bag of FP JB HTZ Black
  233. FS: Used FP HTA71
  234. Dw 300c fp
  235. BBS Wheels with curb rash
  236. BBS Wheels in Good Condition
  237. Mostly NIB Aftermarket Parts (MHI 18K Turbo, ID1000 Injectors, Whiteline RCK, etc..
  238. New Mfactory 4.0 final drive for ix 6mt
  239. Hoosier Tires 245/40/17 new set of 4
  240. Lancer Evolution X Seats - Leather - Pair
  241. ISO: Valve Cover
  242. 1994 Acura Integra SCCA ITA Current Logbook and Extensive spares. Ready to Race
  243. Efr 7670 1.05 ar *new in box*
  244. Efr 7670 1.05 ar *new in box*
  245. EVO 8 OEM Wheel
  246. BTB: one EVO 8 OEM wheel
  247. 2003 Evo 8 lots of Mods!
  248. Shell for sale
  249. JDM Evo 8 Tail Lights (Crack in one)
  250. Tanabe Medallion Touring Exhaust for Mitsubishi Evolution 8 and 9
