View Full Version : Marketplace
Pages :
1]
11
12
13
14
15
16
17
18
19
20
- D2coilover suspension
- BR V-Band 3 inch high flow cat
- BR lower intercooler pipe set
- BR compressor Outlet pipe for Evo 9 and FP turbos
- BR 3 inch intake pipe for Evo 8/9
- JDM Evo 9 manual wagon for auction
- BR original billet shift cable bushings for Evo 8/9 5 speed
- Evo 8/9 OEM O2 housing
- Evo 8/9 OEM heat shield for 02 housing.
- Generic Coilovers - EVO 8/9
- WTB Elusive discontinued TACTRIX Openport 2.0
- OBX Racing Sports Turbo Manifold Evo 8/9 turbo manifold
- Open Box Unused Engine Oil Cooler Mishimoto MMOC-25 Evo 8/9
- FIC 1000cc Fuel Injectors Mitsubishi Evo 8 9
- Mitsubishi OEM HVAC Rear Vent Duct for Evo 7/8/9
- Evo 8 Tomei Expreme Exhaust Manifold Heatshield for Evo 4-9
- Evo 8 Stock Injectors
- Evo 8 old turbo set up
- 2003-2006 Mitsubishi Evolution 8 Rear USDM bumper (needs repairs)
- 2003-2006 Mitsubishi Evolution 8 9 Front Bumper (needs repairs)
- 2003-2006 Mitsubishi Evolution 8 MAF Mass Air Flow Sensor Unit x2
- 2003-2006 Mitsubishi Evolution 8 9 4G63T MAF INTAKE
- Gauge Cluster - w/ Ferarri Mod
- Koyo half rad with bungs
- Koyo Half Rad New
- Denso Fuel Pump 195130-3360 EVO 8
- NRG Boost Controller $45
- Looking for a full set of brake dust shields.
- ACT Streetlite Flywheel Evo 8/9
- 6870 turbo with hot parts kit
- WTB. Sheepey race hood exit
- Wanted
- 2005 Mitsubishi Evo 8 Full Engine Mount Set
- 2005 Mitsubishi Evo 8 Fuel Hanger And Walbo Pump
- Carbon fuse box cover for Evo 8/9
- Perrin High Volume Fuel Rail 5/8" bore with stock Evo8 FPR
- Walbro 255 Fuel Pump **NEW**
- FIC Fuel Injector Clinic Injectors 950cc low impedance with connectors
- Driver side Evo 9 MR USDM headlight
- AEM CD-7FG w/ Ohm Racing Dash Mount
- Evo X carbon rear diffuser
- Evo 8/9 OEM Intercooler.
- PR Evo9 MR GG Widebody Vortex Original Owner
- Evo IX Buschur 2.0 long block fully built
- Looking for ETs test pipe
- 3 inch decoy cat converter.
- Upper intercooler pipe. Evo 8/9
- EVO 8 Wing Brackets
- FP 18 psi wastegate canister
- 2003 Mitsubishi Lancer Evolution GSR
- WTB evo 9 driver side lower intercooler pipe mounting bracket.
- WTB Evo 8 / 9 stock exhaust
- Buschur Racing 3 inch V-band high flow cat
- 5 speed for a stock evo 8.
- OpenPort 2.0 Rev H cable. New.
- Evo 4-5-6 thermostat housing.
- Looking for projector headlamps
- Whiteline Front Sway Bar 26mm for Evo 7 8 9
- Cusco Type OS Evo 7 8 9 Front Tower Brace
- Dynatek ARC-2 ignition kit for Evo 7-8-9
- Evo 7/8/9 Phenolic intake manifold spacer
- BR lower intercooler pipe set for stock frame turbos
- BR intake kit for mass air
- WTB Tactrix 2.0 cable
- Evo 8/8 rear driver side seatbelt buckle assembly
- WTB OE steering wheel 8/9
- 2010 Lancer Evolution stock one owner
- OEM Mitsubishi rear license plate bracket for JDM rear bumper cover 6430A068
- Aeromotive fuel rail
- Nakamichi NA350IBTR single DIN stereo
- WTB Electric blue/ 🔵 IX evo Funds available immediately
- COBB Access Port V3 unmarried Evo X
- TiAL QRJ bypass valve - genuine - like new
- BR 65mm stock frame Throttlebody
- AEM Evo 7-8-9 fuel rail
- Mitsubishi Lancer Evolution X Navigation GPS Player Receiver Screen
- SoCal Evo9 MR WW, one owner
- WTB: Evo 8/9 rear glass
- Evo 8 Head
- Evo 8 Wiseco HD pistons 87mm - set of 4
- Mitsubish Lancer Evolution 8/9 Non OEM Turbo Manifold
- Evo 8 intake valves sku#1826
- Mitsubishi Lancer 2003-2005 non Evo Axles $200
- Precision 6466 BB gen 2 turbo
- BR cam sensor heat shields
- Torque Solutions rear trans mount
- BR V-Band 3 inch exhaust TP and High flow Cat
- WTB Harness Bar
- 6262 complete turbo kit.
- BR race core intercooler kit.
- Looking for 1 BBS MR wheel
- Evo 9 brand new oem short block
- EVO 9 HEAD Arlington Machine Shop Built
- Evo 8/9 crash bar
- Buschur Evolution 3" High Flow Cat
- Cup holder and joint wiring
- 2006 Mitsubishi Lancer Evolution IX MR SE, mostly stock, engine has low miles.
- DC sports EVO tubular header- coated.
- Tubular 02 housing. 2000 plus coated.
- Evo X GrimmSpeed 3 port Boost Controller
- Evo X Walbro 255 used
- Evo X stock cam set
- Evo X full Set Centric Premium Rotors (new)
- Evo X full set Hawk HPS Pads (New)
- Evo X stock shifter
- Evo X Stock O2 Housing
- Evo X stock IC and Piping
- Lancer Evolution Injector Resistor
- WTB- Evo 8 AEM V1/V2
- LINK ECU G4X PlugIn EVO 8 ( 4-8) Brand New In Box * 4 Plug model*
- Manley Turbo Tuff I-Beam Rods
- OEM black Evo9 floormats, no heel hole in driver's mat, very clean
- 2010 Mitsubishi Lancer Evolution MR SST
- 2005 Mitsubhishi Evo 8 Electric Blue 45k Miles 800HP.
- Shaftworks Bilanx Competition suspension 3 way remotes
- USED Mishimoto Baffled Oil Catch Can
- Evo X Turbo kit, used
- Evo 9 OEM USDM HID Headlight (Pair) in Mint Condition. (Unopened/Unmodified)
- MINT 2003-2006 Mitsubishi Evolution Evo 8-9 Evolution Tail Lights Set OEM
- 2006 Mitsubishi Evolution
- Evo X Front Raybestos ST47 brake pads track pads GLOC R12 rear brake pads
- Koyo HH-Series 48mm Radiator for Evo 7/8/9 (HH031610)
- WTB 03-06 Evolution with under 5k Miles. Stock
- New FP Cast o2 Housing
- New FP Zero Turbo
- New TiAL Sport MVS 38mm Wastegate
- Wtb, APR front strut bar and WORKS front strut bar
- Evo 8 Turbo w/tubular manifold/ aftermkt o2 housing lines
- Stock Frame Turbo downpipes 3"
- New Enkei Japan PF06 17x9 +22 machined white
- Advan Racing RGIII rg3 hyper black
- Used Injen Evo 8/9 Downpipe (SES1898DP) *Discontinued*
- USED - Blouch Evo 9 Dominator 1.0XT Turbo (Journal Bearing)
- NEW Mitsubishi OEM Fusible Link Box for Evo X (8571A019)
- Redline good steering wheel cover
- Morrison Fabrications short runner vband hot parts kit
- Bulit by TRE 5 Speed Transmission 4.11 FD
- USED STM 680 Small Battery Kit for Evo 7/8/9
- NEW ETS Lower Intercooler Pipe for Evo 8/9 (Wrinkle Black)
- Evo 7/8/9 Stock Rebuilt Turbo
- NEW ETS Speed Density Intake for Evo 8/9
- 2010 Mitsubishi Lancer Evolution MR-T for sale.
- Rays 57dr 17x9 +22 w/ falken azenis 615 tires
- WTB: Evo 8/9 Lowering springs
- Rize Japan tail lights
- 2003 - 2005 evo viii demon style carbon fiber trunk - vis racing
- Looking for Tactrix 2.0
- Evolution x parts
- ⓔⓥⓞ ⓧ GSR Part Out - Mitsubishi Lancer Evolution EVO 10 CZ4A 4B11 EVO X (SO-CAL)
- Evo 8/9 steering wheel air bag
- Tactrix OpenPort 1.3U cable
- Evo 8 Radio, Speakers, Center Console Cubby, Center Defrost Vent
- EVO 9 OEM Blow Off Valve 1545A001
- A/C Compressor or Clutch & 2 Piece brake rotors
- Exedy Twin Disc
- 2006 Evo lX MR SE
- 4G64 shortblock and Hyundai cy head
- 4G64 shortblock
- Tactrix Openport 2.0
- 🚨Evo X Part Out
- AP Racing Front Brakes
- Evo 8/9 Stoptech Trophy FRONT BBK
- 2010 Mitsubishi Lancer Evolution X MR Touring - Graphite Gray (Mostly Stock)
- 4g64 100mm crank
- EVO IX OEM Front License Plate Mount
- Cylinder head. Kia/Hyundai. Use on Evo 8
- 2006 EVO IX MR OEM Catalytic Converter and Downpipe
- Single owner, garage kept, IX MR SE stock engine/trans/turbo
- Fujitsubo RMO1A Catback Exhaust
- GSC S3 Cams, very low miles Non Mivec
- Garage Clean out: Pod filter, gauge pods, EBC, Oil Pressure/temp gauge
- Multiple stock and aftermarket parts for sale 2003
- Hpt 6466
- Evo 8/9 Stoptech Trophy REAR BBK with EXTRAS!!
- 2006 Lancer Evolution IX SE
- JDM Evo 8 MR **SHELL PART OUT**
- Tactrix OpenPort 2.0 USB EcuFlash and EvoScan Cable
- Id1300 injectors
- Looking for evo 8/9 rs shell
- Wicked White Evo 9
- 2010 Lancer Evolution SE 76k Miles
- WTB - EVO 8 Throttle Cable Clamp
- SuperPro DuroBall Additional Caster Offset Front LCA Inner Rear Bushing Kit - Evo 7/8
- WTB Lancer Evolution IX MR floor mats (set) in perfect condition
- Evo 8 - Power Steering Pump and Reservoir
- 2015 Evolution MR for Sale
- Oem evo 9 mr fuel pump and sending unit , 97k miles
- LTB: 2006 Evo IX MR
- WTB OEM 03-07 Evo 8-9 hood
- SSB Designs Evo 8/9 Front Lower Control Arms
- Mitsubishi Lancer Evolution 4 IV - Odometer
- Mitubishi Lancer Evolution 7 VII parts 2/2
- OEM Evo 8/9 Timing side motor mount bracket
- OEM Evo 8 Oil Filter Housing w/ Cooler
- WTB: Evo 8/9 ARP Mains & ARP Headstuds
- 2006 Mitsubishi Lancer Evolution IX RS Wicked White
- WTB: OEM Trunk Torsion Bar for Evo 7/8/9, LH
- 1998 Mitsubishi Lancer Evolution V GSR LOW MILEAGE
- Looking for Evo 8/9 RUST FREE Shell
- ORC P659 twin disk clutch
- Cobb Accessport Evo X
- WTB: Used Rear Wheel Bearing
- WTB, white , silver, black , manual , socal , evoX
- Id2000cc injectors
- Evo 8/9 Carbing Aluminum Radiator Cooling Plate/Shroud
- WTB: Tactrix 2.0 and other parts
- Gas pedal with sensor and pig tail
- EVO 9 spare wheel carrier bolt
- Wtb: weight shift knob
- 2006 Evo 9 New Parts for Sale
- Mitsubishi X New ACD Pump
- 2011 GSR - Southern CA
- Right Hand Drive Evo 4 GSR
- LF Trunk lid with or without wing
- FS: Volk CE28N 18x9.5 +28 (Perfect Evo 8/9 Fitment)
- 05 Evo backseat belts and buckles
- 1996 Nissan Skyline GT-R V-spec
- Garage Clearance Sale
- WTB: Complete mint trunk carpet/panels for Evo 8/9
- 2010 Mitsubishi lancer evolution x mr touring. LOW MI, CLEAN TITLE, GARAGE KEPT
- Wanted oem 8 rs mirrors
- 127k mile 2006 silver Evo9, in Colorado, clean title, $19k in included mods
- Evo 8-9 airbag
- BNIB Evo 8/9 OEM Turbo Gaskets
- Evo 8/9 OEM Coolant Overflow
- 8k/10k Swift Springs
- Evo 8 head
- Decals custom made to order - your designs - send message for a free quote! (evo)
- Evo 8/9 parts
- OG bronze RE30 18x9.5+35(4)
- 2.2L 4g63 Block
- RAYS Volk Racing LE37 "Top Secret" 18x8.5 For a Lancer Evolution
- 2005 Mitsubishi Evo 8 SSL in Yellow
- 2003-2006 evo drive by wire 80mm throttle body kit
- Blitz Z1 Techno Speed Wheels
- Evo 8-9 Intercooler pipes
- VOLK RACING RE30 OG Bronze
- Evo 8/9/X suspension, brake, wheels: Swift Whiteline Progress STM AMS Enkei TSW Lenso
- WTB: Evo 8 Buschur mustache bar
- Evo 8 valve cover
- Wanting to buy Evo 9 SE seats with red stitching
- BC intake and exhaust valves 4g63
- WTB: 12 tooth or 12-1 trigger plate
- *WTB* Cobb exhaust
- Evo 8/9 AC compressor
- Evo 9 Stock Turbo (Needs rebuild)
- ATS Carbon Hybrid Differentials (LSD)
