Spring rates
Old Dec 8, 2002 | 03:33 AM
wtz's Avatar
wtz
Spring rates
Hi,
Can someone tell me the stock spring rates front and rear on an Evo VII? Lbs or NM is fine.
Thanks,
Old Feb 6, 2004 | 03:46 PM
2literturbos's Avatar
To the top, I wanna know as well.
-James
Old Feb 7, 2004 | 02:34 AM
wtz's Avatar
wtz
Stock Evo spring rates are 225 lbs. front and 260 lbs. rear. This is US spec.
Cheers,
Old Feb 7, 2004 | 07:28 AM
Taz's Avatar
Taz
Wow that's it? 225 and 260? That's really surprising considering the choppy ride. Maybe the valving on the shocks is set to viagra stiff...
Old Feb 9, 2004 | 11:29 AM
JT-KGY's Avatar
Where you find this data?
I posted this question way back... the answer I got was
180 front &
225 rear.... I believe.
Cheers,
Old Feb 9, 2004 | 11:45 AM
93esp's Avatar
I had the stock springs tested by ProParts and the rates were 180 lb/in on the front and 225 lb/in rear. The choppy ride is due to the stock shock valving which appears to be set for much stiffer springs.
Old Feb 9, 2004 | 01:23 PM
JT-KGY's Avatar
Exactly what my friend is telling me... he said that my EVO's ride
is really poor over small bumps... however, seems to be much
less punishing at highway speeds...
Old Feb 14, 2004 | 08:27 PM
wtz's Avatar
wtz
I don't have quite the faith in Pro Parts as I do in Joe Stimola from SRP Engineering. He has been doing spring and shock work with both the SCCA and various pro-series teams forever. I stand by my numbers.
Cheers,
Old Feb 15, 2004 | 05:13 AM
4ringturncoat's Avatar
That is interesting on the stock numbers! Tien S's are only 212 front and 291 rear.
Old Feb 15, 2004 | 06:25 AM
Z1 Performance's Avatar
Joe Stmiloa - there is a name from the past! My partner used to work for him years and years ago
Old Feb 15, 2004 | 11:04 PM
timzcat's Avatar
Lancershop quotes them as 196 front and 268 rear for the S Tech. I can only assume that came from Tein themselves.
Anyone know the rates on the Eibach Pro kit?
Old Feb 16, 2004 | 05:45 AM
tsi90awd's Avatar
Gruppe-S has a number of spring rates listed on their website:
Tien STech, Front: 196 lb/in, Rear: 268 in/in
RSR, Front: 216, Rear: 177
Eibach Pro-Kit, Front: 165, Rear: 140
Japanparts has some numbers for some Ralliart springs:
Front: 280 lb/in, Rear: 307 lb/in
The problem is that the websites don't describe whether the springs have linear or progressive spring rate. You can tell by looking at the springs, but the pictures shown are often kinda small and not at a good angle.
With a progressive spring, the rate increases with more compression, so the spring rate number will depend on how much the spring is compressed.
Generally, linear rate springs are better for performance because they are more predictable.
Old Feb 16, 2004 | 07:52 AM
exhaust_note's Avatar
damn... them ralli art springs are stiff... whats the drop on them???
Old Feb 16, 2004 | 07:56 AM
tsi90awd's Avatar
That site doesn't give any drop information on these springs. I'd like to know that myself. It does show a diagram with Ralliart coilovers that shows a recommended ride height.
http://www.japanparts.com/Pic/pic093/01-01.jpeg
Old Feb 16, 2004 | 09:35 AM
DrMerl's Avatar
Is it better to maintain the stock ratio of fore and aft rates? The Tein's seem to pretty "different" than the rest, I think they also lower the front more than others to give a visual evenness. I ask because I'm looking for the best compromise for pure street driving in all conditions and using the stock struts.
