pulls timing with no knock at all
Old Aug 28, 2006 | 11:23 AM
cbrtrx's Avatar
ive spoke to some people about this but dont understand how to tune around it, in the upper rpm ranges from like 6k on up i added timing in almost all the load cells, from 200 on up to 280, now the car will hit that timing(14 degrees) then pull about 3 degees out then about 300rpm later put it back in , there is no knock and the timing it goes to is no were on my map in any range at that rpms, it seems to do it every pull i make, i heard about the maf seeing to much air and pulling some timing but dont know how to tune around it, any advise? thank you
Old Aug 28, 2006 | 11:32 AM
C6C6CH3vo's Avatar
Mine does that from 3500 to 5000 rpm sometimes - flatening the adjacent load values helped a little.
There are other parameters (from MAF) that effect timing besides knock thight might be at play here
Old Aug 28, 2006 | 11:48 AM
cbrtrx's Avatar
all adjacent load cell were smoothed, i even raised timing up more and smoothed out all load cells around it, it will still drop back to timing that is nowhere around the values i have set and have no knock
Old Aug 28, 2006 | 11:49 AM
Mad_SB's Avatar
You are either over running the load columns or the ecu is seeing knock. I take it evoscan is reporting a knock count of 0? If so then you are overrunning the load columns most likely.
Old Aug 28, 2006 | 12:04 PM
cbrtrx's Avatar
can you please explain in more detail about over running the load columns, yes the evo scan shows no knock, it will drop timng about 3 degrees for about 300rpm then bring some back, and sometimes it will do it again at a slightly higher rpm, this only happens from 6k on up
Old Aug 28, 2006 | 01:24 PM
MalibuJack's Avatar
It means you might have rapidly gone outside of the rightmost column.. If your last column is 280, then you might have hit load of 300.. That sort of thing..
Old Aug 28, 2006 | 02:45 PM
Mad_SB's Avatar
There is a thread in here about rescaling the load tables... it should have all the info you need in order to scale your load table up to 300 or 320 or whatever you choose.
Old Aug 28, 2006 | 04:11 PM
Second Chance's Avatar
Code:
LogID	LogEntryDate	LogEntryTime	LogEntrySeconds	RPM	InjPulseWidth	TPS	AirTemp	KnockSum	TimingAdv	EGRTemp	OCTNumber	Speed	FuelMapLookup	Load
218	8/27/2006	17:09	35.12367	4187.5	7.936	100	102.812	0	16	268.3	255	76	148	130.0004392
219	8/27/2006	17:09	35.27388	4250	9.728	100	101.768	0	11	268.3	255	76	159	149.9153774
220	8/27/2006	17:09	35.4241	4343.75	12.544	100	101.768	0	5	268.3	255	76	175	177.4833429
221	8/27/2006	17:09	35.57432	4437.5	17.152	100	100.724	0	-1	268.3	255	80	181	236.9011326
222	8/27/2006	17:09	35.72453	4562.5	20.48	100	99.68	0	-3	268.3	255	80	180	285.64125
223	8/27/2006	17:09	35.88476	4656.25	18.432	100	98.636	2	-1	268.3	255	80	179	257.8899721
224	8/27/2006	17:09	36.03498	4750	18.176	100	98.636	2	-1	268.3	255	80	180	252.80925
225	8/27/2006	17:09	36.20522	4875	18.432	100	97.592	2	-1	268.3	255	80	180	256.45725
226	8/27/2006	17:09	36.34543	4968.75	18.432	100	97.592	2	-1	268.3	255	86	180	256.45725
227	8/27/2006	17:09	36.47561	5093.75	18.176	100	96.548	1	-1	268.3	255	86	179	254.2215922
228	8/27/2006	17:09	36.6058	5187.5	17.92	100	96.548	1	1	268.3	255	86	178	251.9608146
229	8/27/2006	17:09	36.746	5312.5	17.408	100	96.548	1	2	268.3	255	86	177	245.964661
230	8/27/2006	17:09	36.92626	5375	17.408	100	96.548	1	2	268.3	255	86	175	248.7756857
231	8/27/2006	17:09	37.07648	5531.25	17.152	100	95.504	1	2	268.3	255	98	176	243.6312784
232	8/27/2006	17:09	37.21668	5593.75	17.152	100	95.504	1	4	268.3	255	98	177	242.2548305
233	8/27/2006	17:09	37.36689	5718.75	16.896	100	95.504	0	5	268.3	255	98	178	237.2048596
234	8/27/2006	17:09	37.5071	5843.75	16.64	100	95.504	0	7	265.6	255	98	179	232.2113128
235	8/27/2006	17:09	37.65731	5937.5	16.896	100	95.504	0	7	265.6	255	106	180	234.56925
236	8/27/2006	17:09	37.80753	6031.25	16.896	100	95.504	0	8	265.6	255	106	180	234.56925
237	8/27/2006	17:09	37.96776	6125	16.64	100	94.46	0	9	265.6	255	106	180	230.92125
238	8/27/2006	17:09	38.138	6250	16.128	100	94.46	0	10	265.6	255	106	179	224.8745531
239	8/27/2006	17:09	38.30825	6375	15.872	100	94.46	0	9	265.6	255	106	181	218.7619061
240	8/27/2006	17:09	38.47849	6468.75	15.872	100	94.46	0	12	265.6	255	116	180	219.97725
241	8/27/2006	17:09	38.63872	6593.75	15.616	100	94.46	0	13	265.6	255	116	180	216.32925
242	8/27/2006	17:09	38.80897	6687.5	15.616	100	94.46	0	14	265.6	255	116	180	216.32925
243	8/27/2006	17:09	38.99924	6812.5	15.616	100	94.46	0	11	265.6	255	116	181	215.1340608
244	8/27/2006	17:09	39.15947	6937.5	15.36	100	94.46	0	14	265.6	255	124	193	198.3555699
245	8/27/2006	17:09	39.30969	7031.25	16.384	100	93.416	0	11	265.6	255	124	193	211.9646891
246	8/27/2006	17:09	39.4599	7125	16.128	100	93.416	0	15	265.6	255	124	193	208.5624093
247	8/27/2006	17:09	39.60011	7187.5	16.128	100	93.416	0	12	265.6	255	124	193	208.5624093
248	8/27/2006	17:09	39.76034	7281.25	16.128	100	93.416	0	12	265.6	255	132	193	208.5624093
249	8/27/2006	17:09	39.91055	7343.75	16.384	100	93.416	0	12	265.6	255	132	193	211.9646891
250	8/27/2006	17:09	40.05075	7406.25	16.128	100	93.416	0	12	262.9	255	132	192	209.6486719
251	8/27/2006	17:09	40.19096	7468.75	16.128	100	93.416	0	12	262.9	255	132	192	209.6486719
His car is an ix so his load max is 300. Using the formula posted by jcsanks
=5*513*(F217-0.435)/N217 is used to determine the load
it starts about 6700 rpm(id 242). Jumps from 14 to 11 to 14....
Unless its switching timing maps for one reason, I'm not sure why it's doing this.
Old Aug 29, 2006 | 05:04 AM
jcsbanks's Avatar
This MAY be something to do with the ECU doing noise judgement routines. It may also be to do with boost/RPM limits for knock control as well - there is processing in the ECU related to both of the above.
On a separate note, there is a step enrichment at 7000 RPM on this ECU. AFRMAP and IPW go up together (one before the other which explains the blip in load at 7000 RPM down then up.... This is exactly like a lean spool disable feature on my ECU - I move it to 7500 RPM just before the 7606 rev limiter. I still think this sort of code may well be active on the US Evo IX as well as UK/JDM.
Old Aug 29, 2006 | 07:18 AM
MalibuJack's Avatar
I actually logged that enrichment in one of my runs.. I wasn't sure what it was..
Old Aug 29, 2006 | 07:29 AM
jcsbanks's Avatar
Will need to inspect US code for lean spool stuff then...
The range of noise judgement retard appears to be 1-3 degrees. 3 degrees retard on the log above, maybe it heard a noise and was testing to see if it was knock. Needs more work...
Old Aug 29, 2006 | 07:57 AM
Mad_SB's Avatar
Ahhh, I see, well that looks kinda like the load flopping i have been seeing for some time now, looks kinda like it was jumping from one load cell to another on a diaganol. as in 6500, 260 load and 7000 240 load or something. Did you happen to log the maf reading? If it was maxed over 1600 it won't be of any use though.
Old Aug 29, 2006 | 09:04 AM
C6C6CH3vo's Avatar
So this happens even after reflashing?
If your map is asking to run an extreem amount of timing at unusual loads, it might pull timing before knock ever happens.
Could also be wiring or a problem with the MAF circuit that wont show up with logging.
One question, how did you log the load? Was it calculated by yourself from excel or did you get it to log like we did the OCT number
Old Aug 29, 2006 | 09:57 AM
cbrtrx's Avatar
as discussed in another post im wondering if my conical style filter is affecting my load tables up so high in the rpm were i wouldnt expect the load to be and that is why it might be pulling some timing, the only column i have much lower timing is in the 300 load cells
Old Aug 29, 2006 | 10:17 AM
Ludikraut's Avatar
Originally Posted by jcsbanks
...On a separate note, there is a step enrichment at 7000 RPM on this ECU. AFRMAP and IPW go up together (one before the other which explains the blip in load at 7000 RPM down then up....
Interesting. I was logging this as well during my fuel map tuning ... I've since tuned it out by giving leaner AFR targets in that RPM range (e.g. above 7000).
l8r)
