Locked out of my ECU
Old Sep 18, 2006 | 01:48 PM
kapolani's Avatar
I recently got a custom tune.
I hooked up to my car to download the map for my viewing and noticed that I am now locked out of my ECU.
I didn't know I was going to be locked out. If I knew before hand I would have gone another route.
I was planning on using this map as a basemap.
Has anyone ever experienced this?
And, if so, how did you get around it?
Old Sep 18, 2006 | 01:52 PM
chmodlf's Avatar
Talk to Malibu Jack. He seems to have the best answers in this area
Old Sep 18, 2006 | 03:15 PM
EvOcHaRgeR's Avatar
When you mean locked out do you mean that you can't pull your map or does it pull it and you just can't read the values?
Old Sep 18, 2006 | 04:47 PM
kapolani's Avatar
When I use EcuFlash and try to connect I can't.
It sends init requests and doesn't get a response.
I'm locked out. I can't download the map.
Old Sep 18, 2006 | 04:51 PM
EvOcHaRgeR's Avatar
Who did your custom flash?
Old Sep 18, 2006 | 04:52 PM
Ralph's Avatar
http://www.aktivematrix.com/
Register & contribute to the forums .
Go to "Downloads"
then "ECUFlash Addons and definitions"
then "Mitsubishi ECU Unlocker 1.1 for ECUFlash "
Download..
Run ECU Unlocker, KEEP IT OPEN
Run ECUFlash & Read rom... then Save rom..
Close ECUFlash
Close ECU Unlocker
You can 'unlock' your ecu by changing the init to "0001" then you no longer need to run the unlocker.. ..
Ralph
Old Sep 18, 2006 | 08:39 PM
LEvo77's Avatar
I noticed a couple of times when i downloaded peoples maps i could not read the values. The two maps i couldnt read had a custom flash done recently.
Old Sep 18, 2006 | 08:45 PM
ant_turbo's Avatar
Ya you can get in with the unlocker program but you can read it!!!!
Old Sep 18, 2006 | 10:10 PM
EvOcHaRgeR's Avatar
Yeah, I had some what of a custom flash but wasn't fully completed. However, the values were all messed up but I had a buddy of mine unlock it and change the definition so that I could read the real values.
Old Sep 20, 2006 | 02:05 PM
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
What's up K.
Just wondering how did your buddy change the definitions to reveal the actual values?
Just got mine backed up but I can't decipher anything out of it. Looks way out of wack!
Old Sep 20, 2006 | 02:17 PM
EFIxMR's Avatar
I descrambled the rom for evocharger. We are offering this service for $50. If i can't unscramble the rom we refund your money.
Old Sep 20, 2006 | 03:41 PM
kapolani's Avatar
I'm working on my own app that should be able to make the values readable.
Afterall, it's just hex.
The information is in front of us.
If and when I finish it I'll release the program that will allow others to be able to read their rom.
Old Sep 20, 2006 | 04:18 PM
EvOcHaRgeR's Avatar
Originally Posted by mvm42699
What's up K.
Wassup Mike! if you want to read your values PM EFIxMR (Andy) he will be able to help you out.
Old Jan 8, 2007 | 11:04 AM
ElAnCeR's Avatar
do you use ECUflash to run the unlocker or do you use another program?
Old Jan 8, 2007 | 11:51 AM
burgers22's Avatar
Hi
Start ECUunlocker and leave it running, then start ECUflash, you should be able to download your map.
MB
