dyno and tune the Car tell me what you think
Old Sep 26, 2006 | 02:43 PM
dustin03's Avatar
So I took the car to get tuned and this is what I came out with let me know what you think, and what I need to do to make it better?
Mods are on 92 pump 24 psi
20g 9 5
Hks 272
Alcohol 100% inj.
680 injectors
Upper and lower ic pipes
3 in turbo back with no cat
Old Sep 26, 2006 | 03:07 PM
Noogles's Avatar
you have to smooth out the entire map, looks like your timing and fuel is way off. Specially with smoothing 5 it should be a near perfect line. looks like whom ever tuned the car doens't really understand the load cells.
how much timing do you have between 3k-6.5K rpm
Old Sep 26, 2006 | 04:45 PM
dustin03's Avatar
no one has anything to say
RazorLab's Avatar
Yup, what noogles said. Looks like it still has the factory dip at 5200 even.
Old Sep 26, 2006 | 04:47 PM
KOEvo's Avatar
It looks untuned... The torque line looks like it's going to be flat as a board though. After you get a good tune you should put down good numbers.
Maybe you could bump the boost a little bit, 25 - 27.
Next mod would be FMIC, then a turbo kit.
Nice build.
Old Sep 26, 2006 | 04:48 PM
Noogles's Avatar
If you answer my questions i can tell you what you'll have to modify.
look at the diffrence between my old graph and yours.
My 320 pull was made on 91 octane and 20psi @ 11.5 af(stock cams, injectors, turbo)
my 395 pull was made on 110 octane and 30psi @ 12.1af (stock cams, injectors, turbo)
with smoothing 3 ine looks 100 times better with 5 it would have been perfect.
Old Sep 26, 2006 | 05:32 PM
AlwaysinBoost's Avatar
are you at altitude? those numbers seem waaay low for your mods. I'm sure its either the tune or the altitide.
Old Sep 26, 2006 | 05:40 PM
C6C6CH3vo's Avatar
Get it base flashed first, knocking?
Old Sep 26, 2006 | 05:43 PM
kreionic's Avatar
just making sure. You did say this graph was after you got tuned?
Old Sep 26, 2006 | 06:21 PM
dustin03's Avatar
no that is with a tune I an going to do some logging I will find out the timming
Old Sep 26, 2006 | 07:01 PM
Jim_Patterson's Avatar
Get it retuned with boost ~27psi.
03speclancer
Sep 29, 2014 12:59 AM
03redtype-s
Aug 5, 2007 04:44 AM
playmajohn
42
Apr 30, 2007 07:21 AM
03redtype-s
Oct 11, 2006 01:12 PM
03redtype-s
Oct 3, 2006 05:42 AM
