throttle tip-in adjustment
Old Oct 23, 2006 | 09:15 AM
Noogles's Avatar
Any one have any idea how to adjust throttle tip-in other than with accel-inrichment.
As soon as i tap the gas the AF pegs tiself at 10.0 then lean out after a second or two.
Old Oct 23, 2006 | 09:33 AM
mchuang's Avatar
Try and find out what cells it is hitting when you tip in also and make some adjustments there, but I think accelenrichment is the only variable I can think of that will adjust this. Are you on stock injectors?
Old Oct 23, 2006 | 09:55 AM
Noogles's Avatar
the cells are tunned correctly it happens during the shift between closed loop to open loop fueling.
Old Oct 23, 2006 | 10:51 AM
l2r99gst's Avatar
Are your LTFTs very negative?
This can cause what you are experiencing during the transition from closed to open loop.
Eric
Old Oct 23, 2006 | 11:22 AM
Noogles's Avatar
LTFT's are a flash between 1.9% and 25%
However STFT is at 1.2% and MTFT are at 2.6%
Old Oct 23, 2006 | 12:27 PM
mchuang's Avatar
Noogles is this stock injectors? If so and you on stock T just try and load a stock map and test tip in maybe.
Old Oct 23, 2006 | 12:45 PM
Noogles's Avatar
yeah they are stock injectors while i get my 1000cc's cleaned and rebuilt. it's on the stock map for safety, i guess i'll just have to live with it for now.
EvilEvolution8
Jun 5, 2016 03:10 PM
COBB Tuning
Cobb AccessPORT
95
Sep 24, 2015 07:35 PM
stunt2
May 23, 2011 10:59 AM
Thoe99
May 11, 2011 08:16 PM
timzcat
37
Oct 1, 2005 05:21 AM
