i've read every post on wheel fitment but...
I've narrowed my choices down, and really like the Volk LE37T with the diamond cut lip...
these are available in an 18 x 8.5 +30mm which according to Rays website, they will clear the calipers of the EVO...
Now which tires should i run... i can go with a 245/40 which will make the overall diameter larger by .39", or i can run a 255/35 which will give me an overall diameter smaller by .30"...
I'd like to run the 255 just for the larger contact patch, and it'll look meaner than hell... but i also will have the car dropped 1-1.2" all around and do not want to worry about rubbing on turns and such...
Any input here would be greatly appreciated...
Guest
Posts: n/a
Originally posted by gtr
SO if i decide to go with 8.5 wide TE37's i would have to go with 30mm vs 38mm?
What about TDC is it still 114.5?
You mean PCD (Pitch Circle Diameter)? That's 114.3
Yeah that's what i meant. I dont' know why i'm talking about top dead center with rims
I'm a little confused. Would that LE37's work?
I know standrad size is 17 X 8, 1.5" and 4.5"PCD in inches. If i go 8.5 what changes so it'll be a good fit for TE37's and/or LE37's?
Guest
Posts: n/a
SO if i decide to go with 8.5 wide TE37's i would have to go with 30mm vs 38mm? What about TDC is it still 114.5?
