So....someone forgot to put my braces back on.
Old Jun 21, 2007 | 07:49 PM
Turbo Kyle's Avatar
Thumbs down So....someone forgot to put my braces back on.
One of the 2 shops who worked on my car forgot to put my lower braces back on (the ones by the down pipe) Im not sure how log in have been driving with out them. So....can this hurt my car driving with out them? And what is the best place to get after market braces...because mine are freakin gone.
Old Jun 21, 2007 | 07:59 PM
CRX2EVO's Avatar
they really don't do much, you don't need them
Old Jun 21, 2007 | 08:04 PM
Turbo Kyle's Avatar
Really? Or you just BSing?
Old Jun 21, 2007 | 08:05 PM
CRX2EVO's Avatar
I'm serious. If you search I'm sure you'll find people saying the same thing.
You have seen how thin and flimsy those things are right?
Old Jun 21, 2007 | 08:09 PM
Turbo Kyle's Avatar
Yea....thats true they are kind chitty
Turbolover's Avatar
Forget them, unless you upgrade they (lower brace) are useless
Old Jun 21, 2007 | 08:15 PM
JRB_EVO's Avatar
You can get pretty much any set of aftermarket (Cusco, GTspec, ect) lower arm braces for your car, most of them you will have to shim to achieve clearance between them and a 3in DP. However the ones below are advertised as providers of additional clearance for larger DP's. (You can try to source some used stock lower arm bars!!!)
The Carbing bar lower arm brace is advertised as having clearance for 3in DP's without having to use washers as shims.
There is also the RMR K brace which I have read and it is advertised as being able to provide the necessary clearance for 3in DP's.
Another option is the Perrin sub frame brace which replaces the front stock lower arm bar, this one has a notch to provide extra clearance.
Finally with regards to the statement that the stock ones don't do much; when I installed my AMS TBE, I went out for a test drive, on my way back I took a hard turn, (one that I make at least 2 or 3 times a week) making my way to my apartment, understeer was awful, understeer which was never there before and understeer which I haven't experienced since, because the stock lower arm bars went back in.
Old Jun 21, 2007 | 09:42 PM
Turbo Kyle's Avatar
Thanks for the good info my friend. I want to get some type of brack for sure.....I like my turns
Old Jun 21, 2007 | 10:16 PM
bluebanana23's Avatar
those two are supposed to help with rigidity during hard acceleration. I doubt they do much though.
Old Jun 22, 2007 | 02:42 AM
yikez's Avatar
I have the carbing underbrace...this thing clears my AMS DP with a lot of room to spare.
Old Jun 22, 2007 | 05:08 AM
Turbo Kyle's Avatar
Nice...thanks again
Old Jun 22, 2007 | 05:11 AM
Happy Hazard's Avatar
You need them.
Find a replacement or get the stockers back.
Old Jun 22, 2007 | 06:22 AM
madmax199's Avatar
You sure can drive around without them no problem, but I would not say that they are useless. They do a great job at reducing chassis flex especially in corners; try running a road course or autocross on sticky r-compound without them and you'll apreciate their functionality. I'd rather say that the upgraded ones are the ones that do not do much more than the stockers.
polish_pounder
Oct 9, 2013 03:37 PM
mcm308
11
Mar 21, 2012 02:32 PM
erald01
20
Jan 7, 2011 09:46 AM
pgmike
17
Feb 20, 2005 10:58 AM
pgmike
Lancer How Tos / Installations
Sep 22, 2004 05:58 PM
