Ohlins Sportline coilovers now use DFV technology....
Old Jun 25, 2007 | 01:44 PM
GTWORX.com's Avatar
Just an FYI to all; Ohlins are now better then ever.
Our latest set of Ohlins Sportline single adjustable coilovers that came in is built with the new DFV (Dual Flow Valve) technology AND is dual height adjustable. A pretty solid upgrade over the last generation. Basically they're like the old PCV tech but on both compression and rebound side of things. Better ride quality, better performance, and ride height adjustment seperate from preload is always nice.
So......heads up.
- Andrew
Old Jun 25, 2007 | 06:08 PM
splurta's Avatar
Hey Andrew, thanks for the heads up. Do these new sportlines still use the helper springs or are these eliminated? How do they differ from the Ohlins DFVs (not the ones w/the external reservoirs, the step down before that)?
Thanks!
Old Jul 11, 2007 | 09:14 PM
DaWorstPlaya's Avatar
The Ohlins DFVs that are pretty much replacing the Sportline (PCV) series since the price difference is only $100. It doesn't make sense to buy the Sportline with the older PCV valving when you can get these for $100 more and they come with the newer DFV valving. These are not the Flag series but are one step below that. They have the newer DFV valving that makes for an amazingly smooth ride, yet can firm up to be super stiff (you can feel every bump). There are no helper springs with this setup but spring preload and ride height are seperately adjustable. The setup comes with 8K (450), 10K (560) springs, front camber plates, rear pillow ball mounts, 1 way adjustability (20 click settings). Now for some pics.
Rear bottoms ...
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv1.jpg
Old Jul 11, 2007 | 09:15 PM
Rear top with pillow ball mounts ...
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv2.jpg
Old Jul 11, 2007 | 09:16 PM
Notice seperate spring preload and height adjustability ...
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv3.jpg
Old Jul 11, 2007 | 09:17 PM
Front camber plate ...
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv4.jpg
Old Jul 11, 2007 | 09:18 PM
Look at the beefy front bracket that can take a serious amount of abuse ... also seperate spring preload and height adjustability.
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv5.jpg
Old Jul 11, 2007 | 09:20 PM
DFV technology!!! Damn brakelines are blocking the DFV logo
Buy this from GTWorx!
Attached Thumbnails Ohlins Sportline coilovers now use DFV technology....-dfv6.jpg
Old Jul 11, 2007 | 10:05 PM
Viciouslord's Avatar
and you can own a set of these beautiful coilovers with the life of your first born child...lol.
these are hella nice!
Old Jul 12, 2007 | 08:55 AM
GTWORX.com's Avatar
thanks Suraj for the pics!
- Andrew
Old Jul 12, 2007 | 11:23 AM
justboosted02's Avatar
finally seperate hight and preload, if only the KW 3's had that
Old Jul 12, 2007 | 11:32 AM
Evo23IG's Avatar
I have question, how will these coilovers take the abuse of a winter? Are they rust proof?
Old Jul 12, 2007 | 11:44 AM
SwabeLife's Avatar
+1
Old Jul 12, 2007 | 11:59 AM
GTWORX.com's Avatar
Dan in the office has had Sportlines on his STi and goes to college in nasty winter Ohio. No problems whatsoever in about a year.
He actually has them off the car right now to test another suspension, and the Ohlins are pefect.
- Andrew
Old Jul 12, 2007 | 12:07 PM
Evo23IG's Avatar
Are they stainless steel? Also do you revalve them to custom specs or just use out of the box?
