Lowering Springs *OR* Coilovers
Old Jul 8, 2007 | 08:27 AM
Knightr's Avatar
Ok I have a small problem... the last piece to this add-on buying spree is the suspension with sway bars...
my problem i have talked to so many people and read so many reviews i'm not at a loss.
so i have 2 simple questions
if you do track days of 10-20 per year and it's your daily driver what would you do?
Lowering Springs with Sway bars
CoilOvers with sway bars...
and if you can recommend some of both? i have been looking and looking and WOW i'm lost now... i don't want a 4k solution... but i'm open to all options at this point...
thanks for posting...
Old Jul 8, 2007 | 08:35 AM
cfdfireman1's Avatar
springs and bar, just 1
Old Jul 8, 2007 | 09:16 AM
Knightr's Avatar
any brands, better or worse.... ? used any?
Old Jul 8, 2007 | 11:20 AM
People are running the Espelir or Swift springs and I'm thinking Roispec's new springs should be out by now. Whiteline roll center correction, trailing arm bushings, rear bump steer bushings and a stiff rear bar 25MM should be on your list.
Old Jul 8, 2007 | 07:48 PM
kingman4's Avatar
If its not broke, don't fix it... The car handles great stock. Do a couple events first, then mod, I say. And do it once, do it right... if you're serious about track events, c/o's are the way to go. Poster above me forgot to mention Hotchkis, as far as springs go.
Old Jul 8, 2007 | 07:51 PM
Warrtalon's Avatar
Holy cow, you plan to do 10-20 whole track days each year? Wow, that's a ton, so you have no business going with lowering springs. I recommend coilovers, and leave the sway bars alone.
If you want a basic set that is going to be better than stock all-around without hurting your performance and providing full adjustability, then get the Megan Tracks.
If you want the next step up with a setup that has already has the R&D done for you with everything preset to go out and rip up the track at a relatively low cost, then go with the PIC/Pure Tuning TSOs.
If you want to go to the NEXT level for $2-3k, then do a full Robispec suspension package.
Whatever you do, don't just get springs + sway bars and don't pick a random set of coilovers and add sway bars. Only do sway bars as part of a KNOWN package/combo.
Old Jul 8, 2007 | 08:16 PM
b00stedPin0y's Avatar
You should for sure go with coilovers especially if your going to be doing that many track days a year.
Old Jul 8, 2007 | 09:24 PM
03evo**'s Avatar
coilover...go with the teins there a good price with good performance
Old Jul 8, 2007 | 10:09 PM
sponge bob's Avatar
I do at least ten track days a year and have been running a Robispec basic for two years (well this is my second season with it). My motto is stop modifying and start driving. So many people I know and talk to spend and spend for mods they don't need or know how to utilize, then I hear the crying about how they can’t afford track days. The EVO does amazingly well at track day with just a set of performance brake pads.
So my advice is to leave the suspension alone and spend the rest of your budget on track days. Then after a few years of learning to drive the car and actually being able to drive at the limits consistently you can then make an intelligent choice yourself as to what type of suspension modifications to make.
Old Jul 9, 2007 | 08:21 AM
Call Robi robispec.com
Old Jul 9, 2007 | 09:08 AM
GTWORX.com's Avatar
10-20 track days a year is a LOT.....must be nice!
Anyway, what's your experience level? What tires are you planning on running?
- Andrew
Old Jul 10, 2007 | 01:02 PM
A good read that talks about stock struts, it gets good in July.
https://www.evolutionm.net/forums/sh...d.php?t=263315
Old Jul 10, 2007 | 04:33 PM
Warrtalon's Avatar
NO way, man. Where did you get the "good performance" part?
Old Jul 10, 2007 | 04:40 PM
boostedwrx's Avatar
I agree with everyone else.. if your tracking that much get the coilovers WT mentioned. I only get 2-3 times a year in, so my Swift springs/Hotchkis rear sway suite me perfect.
I would suggest, however, that you hit GTWorx up for some bump steer bushings, they really help!
Old Jul 11, 2007 | 08:43 AM
mexicanevo's Avatar
had springs, selling them since i went with some KW coilovers.
